Lighting HID/Xenon kits, Retrofits and Associated Topics
relay wiring, check my diagram
Old Oct 16, 2008 | 10:56 PM
SHG_James's Avatar
Default relay wiring, check my diagram
if i wanted, could i pull both 12v from the same place?
Modified by jamescardenas07 at 10:15 PM 10/16/2008
Old Oct 17, 2008 | 10:38 AM
BDogggUT34's Avatar
Default Re: relay wiring, check my diagram (jamescardenas07)
Yes that will work and is the "preferred" way to do it. However when i wired up my horn w/ momo steering wheel, i jumpered 86 and 87 to an inline fuse and then to the battery (like you mentioned above). My switch is in the 85 to ground circuit, that way i push the button and it grounds it energizing the relay. It doesnt pull that much current, neither do fogs, so its perfectly fine to do it this way. As long as you fuse it for protection you should be safe. Mine has worked perfectly!
Old Oct 17, 2008 | 01:34 PM
SHG_James's Avatar
Default Re: relay wiring, check my diagram (BDogggUT34)
thanks for the input. i think ill stick to the preferred way
Old Oct 20, 2008 | 02:11 PM
seminis's Avatar
12V from the same place is fine. Although you may want to use a larger gauge wire for the line that delivers 12V to the relay and then onto the fogs. A 15A fuse may be in order as well.
- Just giving you these ideas as I have the factory loom with me.
Old Oct 22, 2008 | 07:43 PM
jdmdc2boi12's Avatar
aye brah not sure if dis wat u need but check it anyway
https://honda-tech.com/zerothread/2380733
Old Oct 25, 2008 | 02:06 AM
SHG_James's Avatar
Default Re: relay wiring, check my diagram (jdmdc2boi12)
16g good for the 12v?
Old Oct 31, 2008 | 04:51 PM
seminis's Avatar
Should be fine.
Old Nov 4, 2008 | 04:36 PM
-=ZAK=-'s Avatar
lol your switch looks like a key =P
leecivic
Aug 25, 2016 09:25 AM
heavyhittersclub
Oct 10, 2008 06:26 PM
imjustagirl
Aug 24, 2007 08:05 PM
Pcart
Oct 23, 2002 04:55 AM
