why did my lude die?
i was drive to work and all of a sudden the engine stops running, i got a jump but did work, so what should i do, and what made the engine stop running?
its a 98 sh
Modified by sirjmj at 10:34 PM 10/16/2008
its a 98 sh
Was it doing anything abnormal when it died? Do you have any check engine lights? It's impossible to troubleshoot something like this without more information. Be specific and give details.
I had a problem like this with my SH. Sometimes it would start sometimes it would take 10 seconds of slow cranking to start and sometimes it wouldnt start at all. I couldn't even jump it, nothing would happen. It turned out being a crazy optima battery I swaped it out and i havnt had to issue since. Just my experience.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirjmj »</TD></TR><TR><TD CLASS="quote">i was drive to work and all of a sudden the engine stops running, i got a jump but did work, so what should i do, and what made the engine stop running?
its a 98 sh
Modified by sirjmj at 10:34 PM 10/16/2008</TD></TR></TABLE>
since you said you jumped it and it worked, i would point a finger at the alt and/or battery. get them tested.
its a 98 sh
yeah if it started up with a jumper than the timing belt isn't fuked
Alternator, or battery is the only options now! If theres low power the starter cranking can almost stop to where its not cranking yet your lights etc will work. Cranking draws alot of ampherage so if your battery / charging system is [freak]ed, likely the main issue you'll notice is poor starting capability.
sleepyitr
May 1, 2008 04:22 PM
1990CIVIC4WD
Sep 26, 2003 07:17 AM
