SMSP high flow cat
Old Oct 16, 2008 | 03:45 PM
LH-93's Avatar
Default SMSP high flow cat
I have a 2000 itr.
Will a smsp high flow cat bolt right on to a T1R 63s exhaust???
thanks any help is appreciated
Old Oct 16, 2008 | 03:52 PM
walker111's Avatar
Default Re: SMSP high flow cat (LH-93)
Dave can make you whatever you want.
Old Oct 16, 2008 | 03:53 PM
LH-93's Avatar
Default Re: SMSP high flow cat (walker111)
is his username on here SMSP???
Old Oct 16, 2008 | 03:58 PM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LH-93 &raquo;</TD></TR><TR><TD CLASS="quote">is his username on here SMSP???
Yes
Old Oct 16, 2008 | 04:13 PM
get RIGHT's Avatar
I dont see why it wont.
Old Oct 16, 2008 | 09:59 PM
clem kevin's Avatar
get one, mine is great
Old Oct 17, 2008 | 07:27 AM
LH-93's Avatar
Default Re: (clem kevin)
you got a custom high flow cat and t1r 63s?
Old Oct 17, 2008 | 08:15 AM
JdmTypeRdc2's Avatar
as long as the header you have on is stock or USDM length, then it should bolt right up....
SMSP cats come in different lengths also, so you can get a 12 inch or 16 inch...universal ones, or you can get a direct fit...
With the direct fits, you dont have the choice of bigger inlet and outlet diameters, you just get the stock 2.25 inch.
Old Oct 17, 2008 | 08:19 AM
since the t1r exhaust 2.5 inch diameter piping, you will need to get a cat that will have either a 2.25 inlet/2.5 outlet ( if you have stock header) or you have to order a 2.5 inch inlet/2.5 outlet ( if you have an aftermarket header with a 2.5 inch collector)
The length of the cat would depend on the header strictly...
Old Oct 17, 2008 | 09:59 AM
LH-93's Avatar
Default Re: (JdmTypeRdc2)
alright man thanks bro
Old Oct 18, 2008 | 11:30 AM
LH-93's Avatar
Once i install this stuff am i going to get a CEL because of the new exhaust.
If so what should the code be??
Old Oct 18, 2008 | 11:34 AM
coolhandluke's Avatar
Default Re: (LH-93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LH-93 &raquo;</TD></TR><TR><TD CLASS="quote">Once i install this stuff am i going to get a CEL because of the new exhaust.
If so what should the code be??</TD></TR></TABLE>
You shouldn't get a CEL your exhaust? Just make sure the the cat is for an ODBII vehicle with an O2 sensor bung before and after the cat.
Old Oct 18, 2008 | 12:32 PM
LH-93's Avatar
Default Re: (coolhandluke)
I talked to Dave at SMSP he got me all set up.
now about the o2 sensor????
Old Oct 18, 2008 | 05:58 PM
E-Money's Avatar
Default Re: (LH-93)
great product i have one
Old Oct 19, 2008 | 07:45 AM
OH_1fstgsr's Avatar
Default Re: (E-Money)
I have one. I measure the one under my car called SMSP, Dave, told him what I wanted. I even had an extra O2 bung pre cat for my tunners wide band.
Old Oct 19, 2008 | 08:36 AM
eluam's Avatar
I've got a SMSP high flow cat and love it.
Old Oct 19, 2008 | 09:07 AM
Doespike's Avatar
Default Re: (eluam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eluam &raquo;</TD></TR><TR><TD CLASS="quote">I've got a SMSP high flow cat and love it. </TD></TR></TABLE>
Old Oct 19, 2008 | 09:09 AM
Default Re: (LH-93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LH-93 &raquo;</TD></TR><TR><TD CLASS="quote">I talked to Dave at SMSP he got me all set up.
now about the o2 sensor????</TD></TR></TABLE>
On ODBII vehicles, there are two O2 sensors. One before the cat, and one post cat. When you order the cat from Dave, specify that you will need both bungs.
Old Oct 19, 2008 | 10:33 AM
LH-93's Avatar
K i will do that. Thanks for your help man.
Also i saw that you said that the T1R 63s was discontinued. I also heard that but i see it all over.
Examples-http://jhpusa.com/store/pc/viewPrd.asp?idcategory=353&idproduct=1393
http://www.aj-racing.com/catal...age=2
and a couple others
boosted94teggy
Oct 10, 2005 09:33 AM
one slow coupe
Jan 18, 2005 10:29 AM
TypeR864
Jan 7, 2005 03:22 PM
Stewie
Aug 20, 2002 05:50 AM
citanest
Mar 7, 2002 10:52 AM
