brake lights and reverse lights not working.
No brake lights or reverse lights.All other lights and signals work.Switch at pedal checks okay.All fuses working.Brake lamp dash indicator on..
Help anyone?
Thank you
Its a 97 coupe
Modified by brd at 5:43 PM 10/16/2008
Help anyone?
Thank you
Its a 97 coupe
All bulbs have been replaced.
Fuses all check okay.
Brake lamp indicator on dash has gone off.
Horn works.
Are the reverse lights and brake lights somehow connected or is it coincidence that neither are working?
Horn works.
Removed the brake switch at the pedal.Jumpered the connector without the switch .Brake lights are good.
Now to get a new switch and on to the reverse light problem....
I cant find teh switch anywhere for sale...Know where to get it?
Modified by brd at 6:12 PM 10/16/2008
Yeah ..If only I had jumpered it this AM ,I wouldn't be sitting here this pm without brake lights..Majestic Honda dosent have the part listed ..Any idea where to get it?
Is it possible its called CRUISE CUTOFF SWITCH
Modified by brd at 6:37 PM 10/16/2008
90-97 BRAKE LIGHT SWITCH
Genuine Honda replacement part. Fits models without cruise control only.
Part #2835350
Mine has cruise control....Dont care about cruise .ya think the above one will work,just wont enable cruise function.the cruise model is 43$
90-97 CRUISE CUTOFF SWITCH
Genuine Honda replacement part. This switch shuts off the cruise control when the brakes are applied.
Part #2836750
Seems im limited to 5 posts per day so ill ask here.
Any idea about the back up lights not working?With the car in reverse I do NOT get power at the wires to the bulbs.All fuses do check okay.Im sure of this unlike I was sure of the pedal switch not working....LOL
Modified by brd at 9:15 PM 10/16/2008
Part #2835350
Part #2836750
Different switch - or should be, I would image the cruise switch is tied to the brake switch, but I can't tell you for sure.
The backup lights are probably related to a sensor for the gear shift to be in reverse, let me see if I can find what I'm talking about.
jspinn13
May 6, 2012 08:12 AM
-Whitey-
Feb 24, 2003 01:16 PM
