B16 EF Axles
Old Oct 16, 2008 | 09:53 AM
EJ7CoUpE's Avatar
Default B16 EF Axles
Just picked up a ef wit a jdm b16a and the axles are brand new as the previous owner stated they still have the sticker on them and look brand new. As for the suspension there's skunk2 springs in the rear and ebay coilovers in the front raised up monster trucking. I tried lowering the coilovers in the front to match the height of the skunk2 springs drop but in doing so after lowering it and going for a drive u can hear the axles start clicking at like 10 mph and get worse at higher speeds, but when normal height its fine no noise or anything. He has got an alignment ina while so im thinking it could be that I just wanted to you guys advice on what I need to do to stop this..thanks
Old Oct 16, 2008 | 12:10 PM
zrickety's Avatar
Default Re: B16 EF Axles (EJ7CoUpE)
i don't know exactly what axles you have or how low you are going, but you will probably need some good hybrid axles, like raxles. clicking is bad
Old Oct 16, 2008 | 12:54 PM
EJ7CoUpE's Avatar
Default Re: B16 EF Axles (zrickety)
What does the clicking mean? There's 94 integra axles on there right now..and where do I get these hybrid axles from? I was planning on getting function and form type 1's and dropping it just on the tires no gap not dumped but def low as hell
Old Oct 16, 2008 | 01:00 PM
vtecb18c's Avatar
clicking starts with bad cv joints...but seein how it doesnt click when you keep the car at stock height i would suspect its just the axle pitch...there has to be a reason why when you bought the car, front end was up high...it could be a suspension problem...i would just go out and get a set of S2 fronts and ditch the coilovers
b18-c-rx
Apr 18, 2005 07:26 PM
steronz
Apr 5, 2005 02:41 PM
EeeJayEight
Jun 21, 2004 03:16 AM
B20BHatch
May 6, 2004 05:12 PM
