Cleaning Out Garage Sale:CHEAP!! Lots of parts.
OK so I'm cleaning out the garage and need to get rid of all these parts laying around. . .All parts are pretty much firm and picked up in Pinellas Park.Here it goes:
EF engine fuse box/panel $5:
EF SI gauge cluster 133k miles $25:
Hydro GSR trans(unsure of condition-was told needed syncros but he never used it,could be perfect could grind as-is-atleast case is worth using also)$150:
3 B-series starter(all work great 2 pictured)$35each:
Clear corners $5-top(Vision clears) $2-each middle(2 pass. sides-EG) $5-lower(88-89 crx)-some tabs are broken/cracked some are perfect just dont need or $10 for all 6:
BLACK-Rear hatch plastic,and rear corgo tops left and right for 88-91 Civic hatchback.$20 for all or $10 each:
EG Hatch Clear/Red inner tails(believe they fit 4door also??) $15:
OK all this is in lower pics:
1-Vortech air intake with filters-$15
1-test pipe for 2bolt front 3 bolt rear civic or integra-$15
2-power steering pumps one GSR on 00 Si i beleive-$10each
1-B-series alternator with lower bracket(off 93 teg)-$25-works great
1-pass side 4dr DA corner great condtion-$5
4-PR3 Dome top pistons(95 Del Sol) Factorys great condition-$25set
1-Z6 intake manifold with fuel rail pressure regulator and injectors-$25
1-Z6 fuel rail with regulator-$10
1-B series starter(one of 3 listed above)-$35
OBD-0 ECM's:
1-PM5 ecu-$10
1-PR4 ECU-$15
2-PS9 ECU's-$15each
Ok and that pretty much sum's it up. . Let me know If you need anything.
No trades as I am no longer into the Honda scene everything is sold as-is where-is and is described to the best of my knowledge and condition is as stated. Thanks!!
** Can ship at buyers expense. . **
Modified by thalwr1 at 3:44 PM 10/18/2008
Modified by thalwr1 at 4:41 AM 10/21/2008
OBD-0 ECM's:
1-PM5 ecu-$10
1-PR4 ECU-$15
2-PS9 ECU's-$15each
forceinducted
Jul 13, 2016 11:06 PM
anthonysed3
Jun 4, 2012 04:49 PM
jdmekcoupe96
May 22, 2007 08:11 PM
