leaking head gasket on a si hatch
ok its not leaking that bad wat should i do should i try the sealer shi^ or should i just replace the gasket and wat about the head studs re use the old ones or buy new ones it is only a temporary fix till i get a sir swap for it pleas help
Replace it, you can re-use your old headstuds if they aren't stripped.
I have a brand new headgasket if you want it too, 25 shipped.
Yeah...definitely replace the headgasket. The head and block faces need to be sealed together via the gasket, otherwise the leak will eventually lead to warping of the head mating surface. Thus, you might wanna take your head to a machine shop to have them check for warpage and make it level if needed. This is pretty common for headgasket replacements. I did that with my brother's civic. Machining was cheap. I also reused the head bolts and the car is still running strong (just follow the shop manual and torque the bolts in sequence).
i was was leaning to do the gasket just wanted some others eyes ya know and u relly think it is warrped or possible i have no water in my oil or anything just pushing air into the radiator like i can start it for like 2 min and pop the cap and it goes swooossssshhhh so oh and at my shop we did a block pressure test and it failed that y we think it is the gasket cause of all the stuff is pointing to it
