will frnt knuckle question.
I have a question for you guys i have a set of 99-00 civic si knuckles laying around, would i be able to swap them for my stock 90 si knuckles with brakes and everything? i know the 99-00 brakes are bigger will i run into an issue?
Modified by redb16coupe at 1:37 PM 10/16/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redb16coupe »</TD></TR><TR><TD CLASS="quote">I have a question for you guys i have a set of 99-00 civic si knuckles laying around, would i be able to swap them for my stock 90 si knuckles with brakes and everything? i know the 99-00 brakes are bigger will i run into an issue?
Modified by redb16coupe at 1:37 PM 10/16/2008</TD></TR></TABLE>
They will bolt on but the knuckle curviture is different than the EF so you will most likely have alignment issues.
I would recommend getting a hold of either 90-91 EX Civic or 90-93 Integra knuckles and moving the brake components over from the 99-00 Si onto the DA or 90-91 EX Civic knuckle.
Don't be fooled by junkyards who say that 88-91 Si knuckles are the same as 90-91 EX Civic knuckles because they are not.
tegboy07
Oct 26, 2008 12:28 PM
Arvid
May 16, 2004 09:56 AM
