Loose Steering wheel
Old Oct 16, 2008 | 08:38 AM
justinw's Avatar
Default Loose Steering wheel
I'm sure the easiest way to fix a loose steering wheel is to replace it, however, I noticed a small hole on the back side (top) of the wheel. Has anyone ever injected some type of glue/epoxy into that hole to stiffen there wheel? Thanks
Old Oct 16, 2008 | 08:58 AM
Ermil's Avatar
Default Re: Loose Steering wheel (justinw)
Wow. Don't inject stuff into your steering wheel. Remove the center cap and tighten the nut that threads onto the shaft.
Old Oct 16, 2008 | 09:04 AM
Khmi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil &raquo;</TD></TR><TR><TD CLASS="quote">Wow. Don't inject stuff into your steering wheel. Remove the center cap and tighten the nut that threads onto the shaft.</TD></TR></TABLE>
take a flathead and pry off the H. Then 19mm with extension and tighten down the wheel.
Old Oct 16, 2008 | 09:17 AM
jimihendrixbro's Avatar
easy fix. the h pops out easily. torque down the nut.
Old Oct 16, 2008 | 10:24 AM
EvanFullwood's Avatar
Duct Tape, and zip ties will fix it.......
Old Oct 16, 2008 | 10:26 AM
crxfreak1117's Avatar
Default Re: (EvanFullwood)
im pretty sure he is talkin about the grip on the steering wheel being loose not the actual steering wheel
Old Oct 16, 2008 | 10:31 AM
fireant's Avatar
I think justinw is talking about the rubbery grip of the wheel coming loose from the framework inside it. If its not too far gone, a nice leather cover can make it feel firmer. I highly recommend Wheelskins.
Old Oct 16, 2008 | 11:11 AM
wasabivtec's Avatar
Default Re: (fireant)
If your talking about the rubber grip just being loose...you can try some epoxy it holds up for a few months
Gotrek
11
Nov 5, 2008 05:47 AM
turboITR#704
Jan 8, 2008 12:37 AM
civicDX2178
Jul 5, 2006 01:17 PM
krnboynemesis
Jul 14, 2005 09:44 AM
b16acrxer
10
Dec 2, 2003 06:28 PM
