Driveshaft replacement
Old Oct 16, 2008 | 04:31 AM
tmugg's Avatar
Default Driveshaft replacement
Help
Started with a brake noise in the right front. Ripped it down and found right front brakes gone, rotor scored bad and outer CV boot split.
Since I am going to split the hub I though I would change the whole shaft (158K on car).
Does the shaft seperate fairly easy on the transaxle side? I don't want get into the tranny.
Any advice would be appreciated.
Thanx
TJ
Old Oct 16, 2008 | 04:45 AM
dtapia's Avatar
Default Re: Driveshaft replacement (tmugg)
yes a very simple task
Old Oct 16, 2008 | 04:57 AM
GhostAccord's Avatar
Default Re: Driveshaft replacement (dtapia)
x2
A pry bar between the transmission and the inner CV joint. A light push/pull on the pry bar and it should pop right out. Try to get the pry bar tip in as close to the spline as possible to avoid any sort of side loading/binding.
Old Oct 16, 2008 | 05:01 AM
tmugg's Avatar
Default Re: Driveshaft replacement (GhostAccord)
Thanks a bunch. I will go at it!
soysauce90CRXsi
Sep 10, 2008 09:15 AM
iwanttogofast
Jan 31, 2007 03:22 PM
all_conference
Suspension & Brakes
Aug 16, 2006 12:03 PM
Rocks
Jun 27, 2004 04:23 PM
xvracing
Mar 27, 2003 03:10 PM
