Do I have to slice and splice the injector clips on to My DX Harness
Do I have to slice and splice the H22 injector clips on to My DX Harness because the DX clips aren't plugging up to the Hseries injectors. They are bothe OBD1 the clips are 95% identical but one little thing sticking out on the inside of Hseries injector
Just pull the pins and swap clips, its easier than splicing. Yes you do have to change them, OBD1 h22a plugs are differant than D-series plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e46civic »</TD></TR><TR><TD CLASS="quote">Just pull the pins and swap clips, its easier than splicing. Yes you do have to change them, OBD1 h22a plugs are differant than D-series plugs.</TD></TR></TABLE>
not true at all i have h22 injectors in a d16 right now and i didnt change plugs
if you a 96 on up then you have to change the injector plugs
^Sammy]!.
Sep 12, 2006 11:07 AM
crex23
May 24, 2005 05:57 AM
