Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Megan Racing Coilovers D2 Coilovers Ksport Coilover sale, Kontrol Pro, GT pro,
Old Oct 15, 2008 | 11:04 PM
Honda Gen's Avatar
Default Megan Racing Coilovers D2 Coilovers Ksport Coilover sale, Kontrol Pro, GT pro,
Ksport Coilovers
Ksport Kontrol Pro Fully Adjustable Coilover Kits are specifically designed to extract maximum out of your car by using the state-of-the-art suspension technology. The highlight of these special coilover kits is the use of 36 levels of dampening adjustment, which enables fine-tuning of the ride according to your handling and comfort requirements, as well as offers ease of adjusting of compression and rebound simultaneously. These coilover kits also feature pillow ball mounts in the front and rear that help in maintaining vehicle manufacturer suspension geometry design. The benefits of these pillow ball mounts also extend to offering better direct feeling for solid driver response. Moreover, camber adjustability is also included on these mounts to allow the user to easily adjust camber from the actual coilover, instead of a separate camber kit.
The use of an adjustable lower mount in some application allows you to adjust height without losing suspension travel. The features include, designing of the mounts and most pieces of coilover for 6061 billet aluminum, lightweight, durability, rust resistance, zinc-electroplated steel shock body, and matched valving of each set to the springs installed to offer the best ride quality with world-class reliability from the manufacturers.
Ksport systems are Monotube-designed, which means that oil and gas are separated within the cylinder. In simple terms, it means that Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process than the Twin-tube designs.
Ksport Kontrol Pro Fully Adjustable Coilover Kits are aimed at providing maximum performance and value for
Ksport Kontrol Pro Coilovers
Modified by ERZperformance.com at 8:09 AM 10/16/2008
Old Oct 15, 2008 | 11:09 PM
Honda Gen's Avatar
Default Re: Megan Racing Coilovers D2 Coilovers Ksport Coilover sale, Kontrol Pro, GT pro, (ERZperformance.c
Ksport Rally AR Spec Damper System is ideal for enthusiasts who love asphalt rally competition. This unique Damper System utilizes extended stroke, heavy-duty internals, and simultaneous compression and rebound adjustment to offer maximum out of your vehicle under extreme conditions.
The highlight of this special Damper System is the use of 36 levels of dampening adjustment, which enables fine-tuning of the ride according to your handling and comfort requirements, as well as adjusts compression and rebound simultaneously to offer ease of adjustment. These coilover kits also feature pillow ball mounts in the front and rear that help in maintaining vehicle manufacturer suspension geometry design. The benefits of these pillow ball mounts also extend to offering better direct feeling for solid driver response. Moreover, camber adjustability is also included on these mounts to allow the user to easily adjust camber from the actual coilover, instead of a separate camber kit.
Ksport Rally Spec AR Damper System
Old Oct 15, 2008 | 11:20 PM
Honda Gen's Avatar
also
Ksport Rally Spec GR Type Damper System is ideal for enthusiasts who love gravel rally competition. This unique Damper System utilizes longer stroke, durable construction, and simultaneous compression and rebound adjustment to offer maximum out of your vehicle under extreme conditions.
Ksport Rally Spec GR Damper System
Old Oct 22, 2008 | 01:28 AM
Honda Gen's Avatar
BUMP
Old Oct 28, 2008 | 01:29 AM
Honda Gen's Avatar
BUMP
Old Oct 28, 2008 | 02:05 AM
Honda Gen's Avatar
BC coilover also on sale now
General
- Mono-tube shock design
- 30 levels of damping force
- Pillowball mounts and adjustable camber plates included
- Adjustable rear camber plates available
- Separate Full length height adjustable
- Inverted and Non-Inverted setups
- One year warranty
- Rebuildable
Technical
- Coilovers use 46mm pistons and 53mm shock housings.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve lif
- Iron lower brackets on MacPherson struts to ensure rigidity
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion
- e. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
BC Coilovers
Old Oct 28, 2008 | 02:06 AM
Honda Gen's Avatar
Megan Racing Street Coilover Kits are one of their kinds in the market today. It is a full coilover kit, which has 32-way adjustable shock to adjust the stiffness, and comprises of high-performance shocks and coilover springs. The coilover kit settings 1-8 are quite stiff and recommended only for track use. The coilover kit settings 9-16 are less aggressive and recommended for aggressive use, or for the users who like to have a slightly stiff suspension on the street. The coilover kit settings 17-32 can be easily adjusted to offer a nice pleasant ride and recommended for common everyday street use. With the Megan Racing Street Coilover Kits, you can easily adjust the ride height to your liking with CNC machined locking perches. This kit also comes with fully adjustable front upper pillow ball mounts to allow you to tune your camber. The Megan Racing Street Coilover Kits can perform the functions of both a coilover kit and camber kit. The suspension springs used in this kit undergo rigorous testing up to 500,000 times with compression inspection before being cleared for installation in the kit. These kits offer less than 5% deformation and high-strength sophisticated coating to beat the best in the business.
Old Oct 28, 2008 | 03:52 PM
Honda Gen's Avatar
Skunk2 Pro-Series high performance coilovers are especially designed using state-of-the-art technology to make your road racing and drag racing experience memorable. Skunk2 Pro-Series is the result of high-end testing and employing a rich suspension-tuning experience to the coilovers. And the ultimate result is achieved in the form of spirited performance driving. Featuring shortened shock bodies and shortened shaft strokes for maintenance of suspension travel on lowered vehicles, Skunk2 Pro-Series offers a rare opportunity for the drivers to quickly and precisely set ride heights and corner weights. These special features enhance the vehicle’s capability to handle response, corner ability, stability, and balance. Available in Skunk nonadjustable dual-tube PRO-S design, or Skunk PRO-C adjustable mono-tube design, the Skunk2 Pro-Series Coilover kit includes hard-anodized CNC-machined forged 6061-T6 spring perches, and Skunk2 CNC-wound racing springs made from SAE9254V spring steel.
Skunk2 Full Coilovers kit
Old Oct 28, 2008 | 03:54 PM
Honda Gen's Avatar
The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts*. Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
Key Features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (not available for some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
D2 Coilover kit
Old Oct 29, 2008 | 06:39 PM
Honda Gen's Avatar
bump
Old Nov 5, 2008 | 12:49 AM
Honda Gen's Avatar
bump
Old Nov 13, 2008 | 02:11 AM
Honda Gen's Avatar
BUMP
Old Nov 15, 2008 | 11:36 AM
Honda Gen's Avatar
BUMP all order shipped
ThrowdownPerfor
19
May 17, 2011 12:29 PM
acuteperformance
64
Jan 26, 2008 11:41 AM
JGDynasty
32
Jun 20, 2007 09:24 AM
FlippY_O
Aug 10, 2005 12:34 PM
RiChi
Jul 27, 2005 08:55 AM
