<<HELP>>Code 6 is the ECT, how to fix the problem (searched)
Old Oct 15, 2008 | 06:29 PM
busychild's Avatar
Default <<HELP>>Code 6 is the ECT, how to fix the problem (searched)
Basically I was throwing the code 6 and 4. Upon further inspection, I found the pictures below; the wire was so brittle that it had cracked and broken at the plug.
My question is, how can I repair this correctly?
My problem: As you can see from pics, the amount of wire coming from the plug is minimal to none. Can that plug be re-pinned or fixed? <U>HOW?</U>
BORROWED this pic from Mista Bone, sensor directly below the dist. inlet.
Old Oct 15, 2008 | 08:15 PM
crxfreak1117's Avatar
Default Re: <<HELP>>Code 6 is the ECT, how to fix the problem (busychild)
i ran into the same problem 3 days ago when i was puttin my motor back in same thing happened the wire broke at the plug..
what i would do go to a local junkyard and go to any honda they all carry the same temp sensor and find one that the wires look good and not brittle and cut the plug off of the harness about 6 inched of wire attached to the plug and cut and resoulder the plug into ur harness (luckly i had a parts car integra i got mine off of)
dabeast111
Jun 5, 2011 08:43 PM
SolAssassin
10
Jun 26, 2009 01:31 PM
jpnucrx
Jun 17, 2006 09:44 AM
2DoorBandit
May 3, 2006 07:45 PM
civic2000
Jan 6, 2005 07:35 AM
