New Honda owner with some questions
Old Oct 15, 2008 | 04:16 PM
986ci's's Avatar
Default New Honda owner with some questions
Just bought a daily for my daily, lol. it's a 1988 Accord 5 speed, now it has some issues, 1st being the front left hub needs replaced (bearings are shot) started pulling that apart but the main nut is giving me issues on coming off. 2nd unless the changed the bolt from what it should be, I could not find where the fill plug is for the trans (found the drain plug, 5 speed) So 2 questions, the front wheel hub needs replaced when you do bearing right? 2nd where is the fill plug on this transmission.
Old Oct 15, 2008 | 05:48 PM
sfcd5's Avatar
i had the same problem with the main nut. youll need a hub puller. just rent one from kragen for like $6 a day.
Old Oct 15, 2008 | 08:08 PM
986ci's's Avatar
Default Re: (sfcd5)
well got the axle nut off and thanks for the advise on the hub puller, almost thought about just getting a used spindle from a junk yard. also can someone post a pic of the fill plug on the trans looked more today and could not find it anywhere.
I did however get the oil changed, puller the timing belt cover and the belt is fairly new and started going over all vacum and radiator lines checking for brittle rubber.
Old Oct 15, 2008 | 08:15 PM
TheMuffinMan's Avatar
He knows where you live!
5spd?
I believe it's the same on F23 as the F22, there are two bolts visible if you take off the passenger wheel on the tranny. One is up and to the left, the other is close to the very bottom.
Bottom is drain, the one up and to the left is the fill, I use a long tubed funnel from the top of the engine bay to reach it, fill it until the fluid reaches the bottom of the threads. You should be able to use a 3/8th ratched to remove the bolts (it has the square indention on it)
Old Oct 16, 2008 | 06:54 AM
986ci's's Avatar
Default Re: (TheMuffinMan)
yea it's a 5spd, and I knew it was a 3/8 drive nut, but can't find the thing anywhere, found the drain plug, so was wondering if anyone had a pic. There is however a 5/8 bolt kinda up to the left right by the cv axle
L2ILL
Jun 28, 2011 06:05 AM
PoWeRBaN_PaNdA
Jan 19, 2009 05:24 PM
my93accord
Aug 1, 2007 07:15 PM
superburner2
Nov 12, 2004 04:04 AM
h22a SaPpY
Aug 12, 2004 10:59 PM
