Tranny problem! NEED HELP
Ok here's what happend im driving home a few nights ago and i was going from third gear to fouth as i was switching it wouldnt go into fouth. I tried to put it in another gear and it wouldnt let me. It just locked up on me i was only 2 minutes away from home. So i turned the car off and it went into gear. I had put it in 2nd and turned the car on . i drove the rest of the way home in 2nd gear. I lifted the car up and turned it on. while it was in the air it was taking all the gear like if it was driving fine, but as soon as i put it back on the ground it would not go into gear. What i was thinking is my clutch is no good because when i stepped on it , it dont feel the same as it did before. Can someone explain to me whats wrong
definatly sounds like a clutch problem wat kind of clutch do u have and how old is it? i had a similiar problem and it ended up being a bad throwout bearing and i destroyed a stage 3 pressure plate.
Rocks.
Aug 22, 2005 03:12 PM
D15VTEC
Mar 19, 2003 05:17 AM
itr1244
Sep 15, 2002 08:57 AM
