car wont start help
Old Oct 15, 2008 | 11:14 AM
Slotz_HB's Avatar
Default car wont start help
oki so i switched the head on my hatch d15b1 (had nastsy lookin valves)
so know that i switched the head im not gettin spark to plugs and plugs smell like gas,what could have happened just from switchin the head please help i need my car its my only car and my dd
Old Oct 15, 2008 | 11:18 AM
Duane_in_Japan's Avatar
Default Re: car wont start help (Slotz_HB)
Mechanical timing, valve adjustment, vacuum leak, under fuel injection, over fuel injection, ignition timing, compression too low, rag stuck in intake or trottlebody, something not plugged in, something plugged into the wrong socket x2, should I continue, which car year do you have and what do you have to test with besides your eyes and nose please.
Old Oct 15, 2008 | 11:41 AM
Slotz_HB's Avatar
Default Re: car wont start help (Duane_in_Japan)
91 std hatch.and i have basic tools and eyes ears and nose,car sounds like it trying to start way to hard,head only has 46k on it from a wrecked civic
Old Oct 15, 2008 | 12:16 PM
JDM EF CR-X's Avatar
u replace the head gasket ?
Old Oct 15, 2008 | 12:19 PM
Default Re: car wont start help (JDM EF CR-X)
no spark check ur rotor on ur dizzy it might of came lose ???
Old Oct 15, 2008 | 01:48 PM
Slotz_HB's Avatar
yes i replaced all gaskets
Old Oct 15, 2008 | 02:48 PM
civicmulisha's Avatar
you might have a bad ignitor or coil did u check those yet
sorry for the double post but mine just shut of out of no where and it was my ignitor that went bad its just one of those things lol
Old Oct 16, 2008 | 11:35 AM
Slotz_HB's Avatar
Default Re: (civicmulisha)
im new to hondas ,were is the igniter??and how can i tell if its bad??well know it back firing almost every second,and hopw do i time it??
Old Oct 16, 2008 | 10:12 PM
your ignitor is right next to the coil inside the dizzy cap and try a coil first it is a simple easy fix
tchandarlis
Sep 6, 2016 09:33 PM
1990civichatchie
Sep 16, 2006 01:39 PM
stunt_driver
Jun 8, 2005 04:55 AM
wickedplastikman
Jan 18, 2005 10:15 AM
g2turbo
Sep 17, 2003 08:31 PM
