what do to about bad front lca bushings
Old Oct 15, 2008 | 08:10 AM
turboblack2door's Avatar
Default what do to about bad front lca bushings
Can i but new aftermarket lca's or where should i look to find just the bushings and how would i get the stocks out?
Old Oct 15, 2008 | 08:31 AM
knightsef-eg's Avatar
Default Re: what do to about bad front lca bushings (turboblack2door)
try to heat up the bolt till its a cherry red and throw some cold water till its done smoking and sizzling....
yes you can get some new lca skunk 2 make them....megan racing and a few others...
if you can get the bolts out ( they seize up alot) gring the 2 ends of the bolt and nut and just slide the strut off the lca.... hope that helps
Old Oct 15, 2008 | 08:32 AM
also you can get the strut mount bushings parts from any local parts store...
Old Oct 15, 2008 | 08:35 AM
Coltmorris's Avatar
This has been covered many times in this forum. Just type 'bushings' in the search field! Gee wiz! The pros and cons of poly, hard rubber, and oem bushings have been discussed throughly in the suspension forum as well as methods for removings old bushings.
PS myhondapartsstore.com has every oem bushing available cept for rta, so your covered.
wvland
Suspension & Brakes
Jan 5, 2014 02:18 PM
boostinEJ8
Suspension & Brakes
Sep 12, 2013 09:13 AM
SL!M
Oct 17, 2006 11:42 PM
drussell4801
Suspension & Brakes
Apr 29, 2005 10:04 PM
Brian_92GSR
Dec 16, 2001 12:14 AM
