FS turbo 88 crx b16 peak boost precision full race quaife omni lensos
Old Oct 15, 2008 | 07:19 AM
Coppertop's Avatar
Default FS turbo 88 crx b16 peak boost precision full race quaife omni lensos
Located in Greenville SC
Turbo will be traded for a t3/t67 soon
lensos Pending, LOWERD PRICE ON CAR 4000!!!!!
cars latest numbers was on a dyno jet made 300whp and 212 tq on 14psi
car weighs 1990 with half tank of gas and passenger seat bolted in
Suspension
omni power ef coilovers with adjustable ride height
full gsr disc brake swap
4040prop valve
15/16 brake booster
Full Race EF traction bars
Engine
b16 block and head
stock bottom end
99si head with jun valve springs and retainers
arp headstuds
Hasport racing engine mounts
RC 1000cc injectors
gm 3bar
old school spoon TB
old school skunk2 intake manifold
PWR half core radiator with full race high flow slim fan
Tranny
b16 tranny with Quaife LSD (also have a junky LS, i stripped a bolt in the b16 case while switching the lsd over so the b16 guts are in the ls case, ill include the junky ls with the b16 so you know)
avid b series EF shift linkage
B&M short shifter
competition clutch stage 4 6 puck sprung
Turbo kit
Peakboost ftw manifold down pipe and dump tube, the tube and mani are powdercoated black
precision sc34 turbo 57 trim .60/.63 journal bearing
braided SS oil feed and return with restrictor
Precision intercooler 600hp rated end tanks were cut off to make back door, still have precision end tanks to prove it
Custom stainless steel intercooler piping
Tial 50mm bov
tial 38mm wg with 10psi spring
Odds/ends
aluminum Butler racing seat with simpson 5 point harness on STOCK CRX sliding rails, direct bolt in for a crx
walbro 255 if anyone cars
stock crx alloy wheels with 2 bfg 205/60/14 drag radials, and 2 doodoo tires on the back
Not installed
i have a set of SRP pistons used, took the rings off 81.25mm pistons, guessing on the compression they are 8.5:1 mated on eagle 3/8 b16 rods
set of gsr cams
Gold Lenso 13x7.5 with M&H 24x8.5x13 and lenso 15x3 skinnies with toyo 25x3.5x15 total of 5 passes
Turbosmart Boost T controller
Modified by Coppertop at 5:47 PM 10/19/2008
Modified by Coppertop at 11:49 PM 10/19/2008
Old Oct 15, 2008 | 09:35 AM
Coppertop's Avatar
Default Re: FS turbo 88 crx b16 peak boost precision full race quaife omni lensos (Coppertop)
bump
Old Oct 15, 2008 | 09:37 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
boooost
Old Oct 15, 2008 | 01:35 PM
Coppertop's Avatar
yes boost is good. now someone buy this car and let boost be good to you
Old Oct 15, 2008 | 05:10 PM
Coppertop's Avatar
bumpin it up
Old Oct 15, 2008 | 06:12 PM
Fibercation's Avatar
Good Deal
Old Oct 15, 2008 | 09:48 PM
Coppertop's Avatar
Default Re: (Fibercation)
spread the word
Old Oct 16, 2008 | 09:52 AM
Coppertop's Avatar
to the top 5500 OBO
Old Oct 16, 2008 | 12:30 PM
Coppertop's Avatar
TTT
Old Oct 16, 2008 | 09:43 PM
Coppertop's Avatar
bump
Old Oct 18, 2008 | 04:57 PM
Coppertop's Avatar
to the top
Old Oct 18, 2008 | 09:36 PM
ef8status's Avatar
GL With sale
Old Oct 18, 2008 | 10:44 PM
Coppertop's Avatar
thanks bump
Old Oct 19, 2008 | 09:54 AM
Coppertop's Avatar
bump
Old Oct 19, 2008 | 03:35 PM
Coppertop's Avatar
TTT
Old Oct 19, 2008 | 07:49 PM
Coppertop's Avatar
bump lowered price!!!
4000!!!!
Old Oct 20, 2008 | 04:13 AM
Coppertop's Avatar
bump it up
Old Oct 20, 2008 | 04:45 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
bump
Old Oct 20, 2008 | 07:20 AM
Coppertop's Avatar
thanks bump
Old Oct 20, 2008 | 07:28 AM
Morasso's Avatar
been in this car before, freaking SCREAMS when vtec cracks. So awesome.
Bump for brandon
Old Oct 20, 2008 | 07:37 AM
B18PwdCivic's Avatar
how much for the set of lenzos fronts , but let me know for all 4 too
Old Oct 20, 2008 | 08:41 AM
Coppertop's Avatar
Default Re: FS turbo 88 crx b16 peak boost precision full race quaife omni lensos (B18PwdCivic)
they are sold sorry
Old Oct 20, 2008 | 09:16 AM
ATYPR's Avatar
NO!!!!
This car has a ton of power left in it. It will run low 11's on c16 with a retune. Wish I had room for it.
Old Oct 20, 2008 | 01:31 PM
Coppertop's Avatar
thanks bump someones gotta want a fun little car
Old Oct 20, 2008 | 04:30 PM
IndySporty's Avatar
bump for another brandon, trades accepted? Got a gas sipper with clean interior/exterior and alpine headunit with 3000 watt MTX amp and sub in the back (looks stock due to carpeting) 20% tinted runs like new.
