Suspension & Brakes Theory, alignment, spring rates....
How to change SPOON Brake pads on a Type R
Old Oct 14, 2008 | 10:26 PM
Quickridez_3's Avatar
Default How to change SPOON Brake pads on a Type R
what pads do you use? i heard they are oem type r. but i looked in the book and the metal backing looks different. does anyone have the steps and pics of how to correctly change the pads?
Old Oct 17, 2008 | 07:27 AM
jdm4drSi's Avatar
Banned
Default Re: How to change SPOON Brake pads on a Type R (Quickridez_3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickridez_3 &raquo;</TD></TR><TR><TD CLASS="quote">what pads do you use? i heard they are oem type r. </TD></TR></TABLE>
Who are you talking to?
Old Oct 20, 2008 | 12:43 PM
GPNY's Avatar
Default Re: How to change SPOON Brake pads on a Type R (jdm4drSi)
Oem Type R pads work.
I would think most aftermarket pads would also work as long as the metal pad backing is the same shape as the OEM pad. There are 2 tabs on the top of OEM pads which go up against the two black pad retaining screws in the top of the caliper. To change the pads, just take out those 2 bolts and slide the pads out from the top of the caliper.
Kind of tough to describe, but it's really clear when you have the calipers in hand. You DO NOT NEED TO TAKE THE CALIPERS OFF TO SWAP PADS.
dakota1820
Honda Civic (2001 - 2005)
10
Jan 12, 2022 02:44 PM
TypeR324
Honda S2000
46
May 8, 2008 10:38 AM
iwantspeed
10
Oct 13, 2006 11:42 AM
hondaracin24
Nov 19, 2004 02:48 PM
natrl
Jun 10, 2003 09:09 PM
