quick question...
Old Oct 14, 2008 | 09:18 PM
DOHCED8's Avatar
Default quick question...
i picked up a d15b2 that was already multiport swapped, ftw.. anyways.. i am wanting to put dohc zc pistons in but im not sure if they will fit with the 1.5 bore or not.. if anyone has any insight it would be greatly appreciated.. thanks
Old Oct 14, 2008 | 09:52 PM
guysensei's Avatar
Default Re: quick question... (DOHCED8)
This is taken from wiki:
A few D-series variants are labelled "ZC" (usually JDM), but they are not truly a different series.
There are both SOHC and DOHC ZC engines.
The non-VTEC SOHC ZC is similar to the D15Z4 and D16A6 engine, but with more aggressive cam timing.
The VTEC SOHC ZC is identical to the D16Z6, and the DOHC ZC is similar to the D16A1, D16A3, D16A8, D16A9 and D16Z5 engines.
D15B2
* Found in:
o 1988-1991 Honda Civic GL/DX/LX
o 1988-1991 Honda CRX DX
o 1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
o 1990-1995 Honda Concerto (European Market)
+ Displacement : 1493 cm³
+ Bore and stroke : 75 mm X 84.5 mm
+ Rod Length : 134 mm
+ Compression : 9.2:1
+ Power : 92 hp (69 kW) @ 6000 rpm & 119 Nm @ 4500 rpm
+ Valvetrain : SOHC (4 valves per cylinder)
+ Cam Gear : 38 tooth
+ Piston Code : PM3
+ Fuel Control : PGM-FI Dual Point (OBD0)
+ Redline : 6500 rpm (6000 rpm honda concerto)
ZC
*Found in 1988-91 (JDM) Crx si
* Displacement : 1590 cm³
* Bore and Stroke : 75 mm X 90 mm
* 1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1
* 1986-1987 Power : 113 hp (84 kW) @ 6250 rpm Torque : 99 ft·lbf (134 N·m) @ 5500rpm (US)
* 1988-1989 Power : 118 hp (88 kW) @ 6250 rpm Torque: 101 ft·lbf (137 N·m) @ 5500rpm (US)
* 1988-1991 Power : 130 bhp (97 kW) @ 6800 rpm Torque : 106 @ 5700 (JDM)
* Valvetrain : DOHC
* Piston Code 1986-87 : PG6
* Piston Code 1988-89 : PM7
* Fuel Control : OBD-0 MPFI
Modified by guysensei at 10:59 PM 10/14/2008
Old Oct 14, 2008 | 09:55 PM
DOHCED8's Avatar
thanks... i knew the specs of the zc but wasnt sure of the specs of the b2..
Old Oct 14, 2008 | 10:01 PM
guysensei's Avatar
Don't mention it I know the bore is the same but i don't know if the stroke being different will make a difference in the pistons being able to be swapped.
Old Oct 14, 2008 | 10:18 PM
DOHCED8's Avatar
Default Re: quick question... (guysensei)
if nething i may have to notch the rods.. kinda the same way when u put ITR pistons in an LS block
ramos2589
May 29, 2009 06:56 PM
ef89
13
Jan 4, 2009 04:33 PM
jdmef90
16
Sep 7, 2005 08:13 PM
sohcvtecowns
Jul 1, 2004 03:16 PM
EsCo_EsCo
11
Jun 5, 2004 12:01 AM
