leak problem!! healp please 97 prelude
when i have the off it leaks alot
but when the car is on it leak very little
its coming from between the tranny and motor
is it the clutch leaking?
when i first got the car the clutch reservoir was empty and i filled it and it was empty the next day so i filled it again and now its ok
people told me that the seal behind the flywheel maybe leaking
the clutch would fell like its slipping in the cold morning but during the day when its warm it feels ok
could that seal behind the flywheel be leaking? and whats it called
look where your coil pack is. Behind the coil pack is a circular black plastic cap. Its probably comming from under there. It usually drips down and ends up around where your dush shield for your tranny flywheel is.
The coil pack if you don't know is whats to the right of where your intake pipe enters your thortle body. It has a wire that connects to your distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz »</TD></TR><TR><TD CLASS="quote">look where your coil pack is. Behind the coil pack is a circular black plastic cap. Its probably comming from under there. It usually drips down and ends up around where your dush shield for your tranny flywheel is.
The coil pack if you don't know is whats to the right of where your intake pipe enters your thortle body. It has a wire that connects to your distributor.</TD></TR></TABLE>
yea i thkn that might be cause its leaking from the top of my tranny and it always get the mesh thing before the cat
