head swap info needed for my 91 crx
i have a 91 crx with a d15 motor which the head has finally taken a crap after 256thousand miles. i have aquired a d16z6 v-tec head with intake, all sensors, throttle body and gaskets . other than needing the p28 ecu, a distributor to match and a 92-95 engine harness does anyone out there know what else is needed to make this conversion? i would greatly appreciate any help locating info on how to perform this swapo and any of the "little things" that end up needing to be done to help do this....please help i love my car!
I wouldn't recommend putting the head on your worn out old block unless you throw some new rings in there, otherwise it'll be burning oil pretty quick most likely. You should get yourself a D15 with less miles on it or put new rings in yours.
http://crx.honda-perf.org/arti....html
https://honda-tech.com/zerothread?id=635580
Read those... They are all different in certian ways but all refer to doing the mini me swap.
thanks a ton...yes i do plan to put rings in my block..already got them and hope they help take care of everything after i get it all together....
hey , when i opened these threads you sent me i noticed that they were dealing with swappin a d16z6 head onto a d16 non vtec block...do you know of any that specifically deal with putting this head onto a d15 that is in my 1991 honda crx...also any articles on ring replacement would help a ton.
thanks
thanks
superfly662001
18
Nov 17, 2008 07:52 PM
superfly662001
Oct 17, 2008 03:47 PM
EGTeK
Jul 11, 2003 10:17 AM
