EF9 square fog light help
Old Oct 14, 2008 | 03:27 PM
splatter_punk's Avatar
Default EF9 square fog light help
any DIY on putting them on or making the brackets ?? i just baught some but no brackets or i have no idea how far to cut .. anyone ?
Old Oct 15, 2008 | 02:22 AM
jdqcivicp72's Avatar
Default Re: EF9 square fog light help (splatter_punk)
i believe they mount on the metal bumper support. or you can get the brackets off a 88-90 prelude oem fog lights modify those to fit. see where it lines up to then cut. on my 89 civic bumper on the inside it said Bosch or standley or piaa i forgot but theres a cut out for the fog its 4x6 kinda big... good luck
Old Oct 15, 2008 | 03:52 AM
89Turbo_Angel's Avatar
Default Re: EF9 square fog light help (jdqcivicp72)
http://www.jdmuniverse.com/for...xfogs
Old Oct 15, 2008 | 06:47 AM
crx_si-r's Avatar
Default Re: EF9 square fog light help (89Turbo_Angel)
oem crx brackets for the usdm model.....
if you have the metal bracket that bolts the fog lights, then you can search on ebay and look for the guy who is selling and making the replicas. only down side to those brackets is that you need to mod the bumper support. it needs to be notched because the jdm bumper support is different than our support. im thinking of having a place around here fab up some of these for our usdm cars. oh and if you go with the usdm brackets the civic 3D/4D mounting part is different than the ones from our crx. i know because i have a clean set of mounting brackets from a 4Dr and they dont fit my crx.
Old Oct 15, 2008 | 09:08 AM
GurlyHB's Avatar
Default Re: EF9 square fog light help (crx_si-r)
what about for the EF9 front end ?? same process ?? does ther back of the bumper have an outlne of where u need to cut ??
Old Oct 15, 2008 | 09:50 AM
crx_si-r's Avatar
Default Re: EF9 square fog light help (GurlyHB)
from what i remember on my 89 HB there were 2 outlines on the back side of the bumper. 1 outline was for the bosch foglights and the other for the stanley fog lights.
Old Oct 15, 2008 | 10:56 AM
GurlyHB's Avatar
what about the bumper lights ?? how do u make them stay on and blink aswell ?? been trying to do thisbut cant figure it out ..
Old Oct 15, 2008 | 11:44 AM
crx_si-r's Avatar
what i would do in order to make the bumper lights "light up and blink" is i would just tap into my corner lights. one of the bulbs on the corner lights stays on and blinks. but that would be a quick fix.
Old Oct 15, 2008 | 12:13 PM
GurlyHB's Avatar
wait so ull have run the negative and positve wire to the one corner light that stays on constant and blink ?? because i tried that and it only stays on and makes my rear turn sinlas on constant .. or do i have to cut the wires off the socket from the bumper liht and run it to the corner ??
Old Oct 16, 2008 | 09:41 AM
^^ yeah been wanting to do thisd too
Old Oct 16, 2008 | 09:51 AM
crx_si-r's Avatar
no, here is what i did with the side markers on my ej8 coupe.
i took the +/- wires from the side marker and tapped into the + side of both my turn signal and running light. so in other words find both the positve wires from your corner light bulbs and tap the bumper lights into those.
this way my side marker lights are always on when i turn on my lights and when i turn on my turn signal they still blink.
if your still confused lmk, it may sound off but it works.
Old Oct 16, 2008 | 12:18 PM
and what about the (-) ?? ok so on the bumper lights i take the + end and cut it or just splice it and run a wire to my running light and the corner light that blinks ??
Old Oct 16, 2008 | 01:10 PM
crx_si-r's Avatar
run both wires to the positive wire on each light.
Old Oct 16, 2008 | 01:34 PM
ok .. will do .. so the bumper light have 2 + goin to the postives on each light right ?? lol .. sometimes this is confusing .. thanks for the help . as far as the fog light brackets i cant find any so ill prolly make my own
Old Oct 16, 2008 | 04:47 PM
crx_si-r's Avatar
if you want I can take pics of the oem usdm civic cog light brackets if you ned en jus lemme know. Good luck on the ustin brackets if I can find a good shop Im contiplating mass producing these if there is a high enough demand. Keep us osted with your progress.
Old Oct 16, 2008 | 05:37 PM
yeah post them up /// .. ok so i went and did that bumper light thing .. the first time i spliced into the constant and blink and it just keep it on and my rear turn signal on constant too .. the second time i just ran the + wire to the blinker and nada ..
Old Oct 16, 2008 | 10:33 PM
aftermath1312's Avatar
guys..if you want ur bumper lights to stay on and at the same time blink. all you got to do is get the socket with pigtails from and 92-95 civic corner light...hook up ur original two wires to the two wires from the new socket..and the third wire left fromt the new socket run it to the turn signal...finish product should stay on n blink at the same time...i have them on my ef and have no problems...n yes the sockets bolt right up to the bumper lights...
Old Oct 17, 2008 | 07:54 AM
GurlyHB's Avatar
Default Re: EF9 square fog light help (aftermath1312)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aftermath1312 &raquo;</TD></TR><TR><TD CLASS="quote">guys..if you want ur bumper lights to stay on and at the same time blink. all you got to do is get the socket with pigtails from and 92-95 civic corner light...hook up ur original two wires to the two wires from the new socket..and the third wire left fromt the new socket run it to the turn signal...finish product should stay on n blink at the same time...i have them on my ef and have no problems...n yes the sockets bolt right up to the bumper lights... </TD></TR></TABLE>
pics ???
Old Oct 17, 2008 | 09:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GurlyHB &raquo;</TD></TR><TR><TD CLASS="quote">
pics ???</TD></TR></TABLE>
mflannery1980
33
Aug 26, 2011 06:36 PM
vtec95
Jun 22, 2010 08:16 PM
elektronsi
Lighting
Apr 27, 2008 05:25 PM
B18Sleeper
Jan 9, 2007 05:00 AM
user 98292739
Dec 5, 2004 09:34 PM
