1989 accord Power stering problem
Old Oct 14, 2008 | 02:07 PM
surfer_mom3's Avatar
Default 1989 accord Power stering problem
I have an 89 accord and just this last week i have found that i am losing power stering fluid out of the top of the resovor , yes the cap is still on but it some how manages to pop up . i have inspected the lines and can not spot any visable leaks or cracks, and the resovor and cap as well have no visable cracks or leaks it simply just pops up on its own........ can any one please help??
Old Oct 14, 2008 | 03:37 PM
hondadude's Avatar
Default Re: 1989 accord Power stering problem (surfer_mom3)
Never seen this problem...... Is the reservoir over filled? There is a full mark on the side of the reservoir, about 3/4 of the way up
Check to see if the P/S fluid is foaming after running a few minutes, that would indicate a leak on the suction side of the pump.
Old Oct 14, 2008 | 07:19 PM
dtapia's Avatar
you have a air leak in the o rings or the reservoir i have done a ton of p/s pump reseals for this very problem the most common thing i seen what the front pump seal sucking air and it will push the fluid out of the cap.
Old Oct 15, 2008 | 01:43 PM
Default Re: 1989 accord Power stering problem (dtapia)
thank u for your help now im going to go and replace O rings and the resovor thanks guys
Old Oct 15, 2008 | 09:26 PM
dtapia's Avatar
don't forget the front pump seal on it that's one of the biggest sources for that air leak.
Dirk888
Aug 14, 2016 03:54 PM
HornsManiac
Jan 31, 2016 04:24 AM
tnk
Sep 7, 2009 06:08 AM
Lude-Lee
Jan 6, 2008 07:16 AM
ABK
Nov 11, 2005 09:34 PM
