replacing CV AXLE BOOT-need help step by step
Old Oct 14, 2008 | 12:25 PM
midgetguitarist's Avatar
Default replacing CV AXLE BOOT-need help step by step
my front left cv axle boot is done for....
im not a mechanic so could someone direct me in the way to go step by step on how to fix it.
Old Oct 14, 2008 | 12:36 PM
tico's Avatar
Default Re: replacing CV AXLE BOOT-need help step by step (midgetguitarist)
1. jack up car
2. put car on jack stands
3.take off wheels
4. take off 32mm axel nut
5. take off outer-tie rod ball joint castle nut
6. take a 3-5 pound hammer and hit the area around the ball joint. hit it hard enough and it will pop out with one strike. DO NOT HIT THE BALL JOINT AT ALL
7.use a flat head screw driver aand slip it between the axel and trans housing
8. take a couple shop toels and stick them in the differential when u pop the axel shaft out.
the go to autozone or any other parts store and get a replacement axel and repat the process backwards
Old Oct 14, 2008 | 09:52 PM
91civiccross's Avatar
Default Re: replacing CV AXLE BOOT-need help step by step (tico)
Don't bother with the boot, just replace the whole axel. They're cheap and it's actually easier as well.
oldskoolDA6
Jul 9, 2009 11:39 AM
mums_car
Jul 11, 2004 10:44 PM
JinteDgraM
Mar 8, 2004 08:47 PM
S.Celia
Jan 26, 2004 07:24 AM
ArchAngel Sabastian
Aug 21, 2002 08:20 AM
