Suspension & Brakes Theory, alignment, spring rates....
Grease EVERYWHERE but no rip!??
Old Oct 14, 2008 | 10:10 AM
hybrid90's Avatar
Default Grease EVERYWHERE but no rip!??
I jacked up my car to flush the radiator and noticed tons of grease on the tierod and the inside of my rims on the driver's side. I checked all the cv boots and none of them were ripped.
The car seems to drive fine, no clicking or anything. Are there any other places where there are tons of grease that might have leaked out? Can greae from the wheel bearing leak out... and when I say leaked out.. I meant a a lot.
There's like a coating of grease all around the inner side of my rim..
Old Oct 14, 2008 | 11:17 AM
ntegnifong's Avatar
Default Re: Grease EVERYWHERE but no rip!?? (hybrid90)
is there still a clamp on the cv boot at both ends?? squeeze the boot and see if anything comes out.
Old Oct 14, 2008 | 11:42 AM
hybrid90's Avatar
Default Re: Grease EVERYWHERE but no rip!?? (ntegnifong)
Will check that out when I get home.. thanks!
Old Oct 14, 2008 | 04:22 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I had grease spray out of my right inner CV boot, but no rips. Sometimes it just leaks out past the clamp. I replaced the axle as soon as I found the grease had sprayed out.
Old Oct 15, 2008 | 05:17 AM
Targa250R's Avatar
be professional
The outer CV joint is the only component in that area that holds enough grease to coat the inside of the wheel. As the others mentioned, it is likely leaking past the clamp.
Wheel bearings are effectively sealed and will not leak grease externally.
Old Oct 15, 2008 | 11:41 AM
hybrid90's Avatar
Default Re: Grease EVERYWHERE but no rip!?? (Targa250R)
If it is a missing or loose clamp.. can I just spray some grease in there and tighten up the clamp? If so, how much grease do I spray in there? Or it doesn't matter? Thanks for the replies
timcali69
Aug 7, 2007 08:52 AM
zero808
Mar 2, 2006 07:43 PM
tRex99
Sep 14, 2004 09:53 AM
Shaun
Sep 8, 2004 02:35 PM
94FrstWhiteSi
Oct 20, 2002 07:04 PM
