D16y8 in EF!
Ok, i used the search nuthin came up!
Ok, i would like to know if an d16a6 distributor would work with a d16y8, and wouldnt i have to change to d16a6 injectors? what else is needed for it to work in an EF???
thanks
thanks
the d16a6 distrib will bolt to the y8 head with no probs. use the d16a6 wiring warness and ecu. the d16a6 injectors will already be on the harness so use them. use the y8 intake mani tho.
