crx tranny help
Old Oct 13, 2008 | 04:19 PM
harmonator84's Avatar
Default crx tranny help
Ok, the tranny in my 91 crx si is shot. I have a extra transmission laying around from a 89 Hf. I am would like to use this tranny because this car will be used as a DD and the way gas prices is anything could help. I know that the tranny will bolt up and if I am not mistaken they both have the same spline count. But my question is what clutch/flywheel combo would I use. Is the clutch/flywheel from a 91 si the same as a 89 hf? The reason why I am asking is because I already have a new clutch for the 91 si tranny.
I am thinking that the 91 clutch is bigger then the 89...let me know if I am correct on this or if my current 91 clutch will fit on my 89 tranny...
Thanks in advance!
Old Oct 13, 2008 | 05:58 PM
elmalouno's Avatar
Default Re: crx tranny help (harmonator84)
since this is a relatively easy question to answer i am assuming people are fed up with posts that make is obvious the person has not searched for the information previously. try searching the site.
the boycott continues?
Old Oct 13, 2008 | 07:37 PM
welfarepc's Avatar
you can safely use your 91 clutch and flywheel with the 89 hf tranny.
Old Oct 14, 2008 | 03:01 AM
Default Re: (welfarepc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno &raquo;</TD></TR><TR><TD CLASS="quote">since this is a relatively easy question to answer i am assuming people are fed up with posts that make is obvious the person has not searched for the information previously. try searching the site.
the boycott continues? </TD></TR></TABLE>
I completely understand. I remember reading something on it before but its been awhile back. If I am not mistaken there is even a thread in the FAQ about it...but I am not able to locate it. Thanks though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">you can safely use your 91 clutch and flywheel with the 89 hf tranny. </TD></TR></TABLE>
Thanks, I was just making sure...can anyone else assure this?
Old Oct 14, 2008 | 05:54 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">you can safely use your 91 clutch and flywheel with the 89 hf tranny. </TD></TR></TABLE> X2
Reason01
13
May 1, 2010 09:38 AM
wfocrx
Sep 24, 2006 10:46 PM
CRseXy
Jan 4, 2005 07:35 AM
racingant
Apr 13, 2004 11:58 PM
ef9one6
Aug 6, 2003 01:17 PM
