ZC question
teg's didnt come with a ZC they came with a d16a1 which is very similar but totally different mounting points. The ZC came in the CRX. The dohc ZC takes many parts from the d16a6 but also need some parts from a d16a1 gaskets ect if u are rebuilding one. Look it up, ull find parts list
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtmoney2002 »</TD></TR><TR><TD CLASS="quote">teg's didnt come with a ZC they came with a d16a1 which is very similar but totally different mounting points. The ZC came in the CRX. The dohc ZC takes many parts from the d16a6 but also need some parts from a d16a1 gaskets ect if u are rebuilding one. Look it up, ull find parts list </TD></TR></TABLE>
stock for stock the jdm zc is much better motor then a 89 integra d16a1.
Well I have a CRX with a blown motor. I'm looking to buy a ZC motor out of an Integra. Will my D15 tranny mate up? I'm getting the ECU with it. What about the intake/exhaust manifolds?
There's a website I found http://dohc_zc.tripod.com/main.html
It talks about swapping the ZC. Is this info correct?
I'll have to ask this guy if the motor is stock from the Integra, and also if he can find the nomenclature on the block.
Thnx
Modified by MonsterRex at 7:13 PM 10/13/2008
Thnx
Id make sure its stamped,its right on front of the block. And if it is it should bolt right to the tranny.But if its not u might have trouble with the mount on the driver side.but im not sure... exhaust will be the same might have to grind a lil on the manifold just a lil, just fit the exhaust gasket to it and see what u will need to take off. The intake is way different from the d15, not sure if the d16a1 or any of the other tegs intakes will fit but i would get the intake with the motor might be hard to pick up that old stuff i know i have a hard time picking up anything like that,, atleast around here .Yeah the website is ok. all true but a lil limited on info.this website is a pretty good one http://www.thezcr.com, but if u are looking for parts just google dohc ZC parts list ,, ull come up with alot of d16a6 parts that will work. d16a1 gaskets should work
Well as it turns out the guy was false-advertising. The motor is a d16a1. I'm gonna get it anyways because it's the cheapest complete short block around and I need a motor.
Now, the d15 I had before was carbeurated. Being that this d16 is fuel injected, is there anything else that I'm going to need, assuming that all connections for the d15 are still present?
Also, what's the best ECU I should use on this motor?
Thanks.
Thanks.
u can run ethier po8 or p28,and don't let any foll you into thinking the po8 has more aggersive maps cause it don't.i got both stock roms and there almost identical there are small changes in the low cam fuel map on the po8 and thats it.
how hard is it to find after market performance parts for a zc i'm thinking of going with one i have a b16 in right now what do you people think just leave the b16 in or go with a DOHC ZC
keep the b16 , going zc ur going to lower ur hp and they are hard to find aftermarket parts for. b16 u can find anything u need,, and for Monster Rex ,You will have to do a mpfi conversion so the car can run ur fuel injected motor many writeups on H-T , heres one from a different forum http://hondaswap.com/swap-arti...49557/
check this website out also... has a parts list of all jdm zc parts http://www.thezcr.com
tons of information on this website for all your questions..
