Defective ACL bearings for 1991 Honda Civic
Have any of the readers experienced problems with defective ACL bearings in Hondas? I purchased a complete set of standard dimension ACL bearings for a 91 Civic-mains, connecting road and thrust- and experienced two problems. First, one of the original con rod bearings was sprung open and packed that way at the factory.(The shrink wrap plastic was tight around the 8 bearings) ACLs US distributor willingly replaced the set . However, when I installed the con rod bearings recently one was too small and seized the crankshaft even before the cap bolts were tightened to the correct torque. I removed the bearing and discovered two bright bars where the thin, top surface layer of the bearing was worn off merely by turning over the crankshaft by hand. These bars appeared across the bearing opposite the tang, about 1/2 inch from the parting line. The lines appeared at the same place on both the top and bottom bearing shells. The bearing that was too small was coded in exactly the same way as the other six bearings which fit correctly. I had previously measured the journals with a micrometer and all were within factory specs. The original bearing that was removed from that journal after 240K miles appeared pristine. Consequently I am confident that journal does not differ from the other three.
I have always been leery of aftermarket parts but I was told that ACL was an OEM supplier to Toyota's Australian factory and incorrectly assumed their aftermarket bearings were of comparable quality.
Is my experience unique or have other Honda techs had similar experiences with ACL bearings?
PS I purchased replacement bearings made by Taiho, an OES Honda supplier.
Dennis Waller
Dennis Waller
My buddy who builds engines stands by them. Another buddy wont use them because Honda has differant bearings for the same engine and so how can acl sell just one for all....Either way I know any company has a bad batch once in awhile. I've seen plenty of engines work fine with acls and ive seen the same for other bearings...when building an engine you should be paying attention to all the specs and products being used and if you see something funny, stop and make sure its corrected first.
igorka_91
13
Jul 5, 2009 12:29 PM
DennisWaller
Oct 13, 2008 04:44 PM
