Cold intake by pass valve
Old Oct 12, 2008 | 12:14 PM
martiw2's Avatar
Default Cold intake by pass valve
Hi,
I have purchase a AEM bypass about six months ago for my cold air intake and today I found it was cracked it was bolted with no movement at all Theirs one in E bay universal fitment has any body try it? andIs it worth buying and doe's it work the same
Willie
Old Oct 19, 2008 | 08:54 AM
P_Adams's Avatar
Default Re: Cold intake by pass valve (martiw2)
Unless you decide to drive during some of those historic Hurricanes that hit the island, or anticipate participating in an automotive submarine race; I'd save my money.
The AEM bypass valve is of value only if you should drive thru water deeper than your remote mounted air cleaner.
On your question about EBay Cold Air Intakes... If you've had problems with an AEM (rare occasion) you'll most certainly have a problem from one of the knock-offs.
The problem with a lot of C.A.I's are two-fold.
1) Inproperly supported (insufficiently bracketed)
2) Not properly iso-mounted.
What can be expected when you install a component which joins a shaking component with one that's not..... somethings gonna break.
P
P
Modified by P_Adams at 1:00 PM 10/19/2008
Old Oct 20, 2008 | 12:15 PM
professorman's Avatar
Default Re: Cold intake by pass valve (P_Adams)
I would prefer to have the bypass valve than not to. Its cheap insurance against loosing your entire engine. Didnt the bypass valve have rubber tubes where it clamps the hose? How did your last one break?
m0squ1t0
Sep 10, 2009 08:10 AM
Rs-xtacy
May 17, 2007 06:29 AM
xxintegrlxx
Jun 22, 2005 03:38 PM
Ch3miztry
Mar 14, 2005 03:15 PM
