SUB QUESTION ....
i got an o8 si sedan with nav premium sound package but i wanted to install a sub is there a way to just jump harness from the original sub without adding a amp will it work???
what kind of sub are you looking to put in...stock amp probably cant handle most aftermarket subs.
your sedan w/ navi came with the sub in the back?...my friend's didnt
Road House
The sound system is still only powered by 350w. I thought all Si's came with the subwoofer in back. If you hooked up an aftermarket subwoofer to the existing system, (if possible), the aftermarket (I'm assuming also larger) subwoofer would drain the OEM "amplifier", if the "amplifier" was at all capable of even powering the sub.
In other words, you'll need an aftermarket amplifier that is hardwired to the battery to see any reasonable gains in subwoofer amplification.
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
If im not mistaken, Honda sells something that gives you more bass and I think its a better subwoofer. Could be wrong tho, I red it on 8th and dont remember where.
RemoveGiantWingOnYourCar
Aug 1, 2014 07:03 PM
rattler2011
Dec 23, 2010 10:20 AM
imadigitalgod
Audio / Security / Video
18
May 13, 2008 04:00 PM
