Issue with installing ITR strut bar on a LS.
Old Oct 11, 2008 | 09:04 PM
thabao's Avatar
Default Issue with installing ITR strut bar on a LS.
hey,
i just recently recieved my ITR front strut bar, i went to go install it but where there is suppose to be screws pointing up, there were rubber hole plugs. i know the gsr and itr come with strut bars and have those bolts for the strut bar, but how do i install a strut bar on my ls if i dont have them?
how do i got about getting these bolts and what size are they? do they attach to some else other than the strut bar?
Old Oct 11, 2008 | 09:12 PM
egsleepercivic's Avatar
just go to the hardware store and and get some stainless steel nuts and bolts
Old Oct 11, 2008 | 09:15 PM
thabao's Avatar
Default Re: (egsleepercivic)
i figured that but, how do i set them in? can i just get a 8mm bolt and screw it in like normal or does it have to be secured to something first?
Old Oct 11, 2008 | 09:21 PM
akandok's Avatar
Use a 10mm bolt from the bottom and use a 10mm nut on top
Old Oct 11, 2008 | 09:28 PM
mrdeadman's Avatar
They let me pick
Default Re: (akandok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok &raquo;</TD></TR><TR><TD CLASS="quote">Use a 10mm bolt from the bottom and use a 10mm nut on top</TD></TR></TABLE>
I'd use some washers too...
Old Oct 11, 2008 | 09:30 PM
thabao's Avatar
Default Re: (mrdeadman)
thats it? okie then. how do i get the 10mm bolts in? is through the whell well or side the fender?
Old Oct 11, 2008 | 10:00 PM
vietnamezerice's Avatar
Default Re: (thabao)
wheel well take a look, it's not as difficult as it seems
Old Oct 11, 2008 | 10:03 PM
just jack the front of the car up a little and you can get to the bottom of the wholes easy thru the wheel well. I also used washers when I install a gsr bar in my LS
Old Oct 11, 2008 | 10:10 PM
anyone want to take a picture for him?
Old Oct 12, 2008 | 06:27 AM
thabao's Avatar
Default Re: (vietnamezerice)
no pictures thats okie ha. well i just installed it and everything went well. since i was doing this, i finally got to install my ksport front UCA and rear LCA and asr sub frame brace. i cant wait for my ITR sway bar!
Old Oct 12, 2008 | 08:18 PM
akandok's Avatar
good. post some pics of the install
Old Oct 12, 2008 | 08:26 PM
fisherboy1118's Avatar
i also used an rubber washer in the wheel well in addition to the metal one so no water would leak up in there.
Old Oct 13, 2008 | 01:02 PM
ilvi3tkidxx's Avatar
Default Re: Issue with installing ITR strut bar on a LS. (thabao)
the way i did mines was using a bolt, stick it through the hole and though the strut bar.. and a nut on top...
apalmucci
22
Mar 23, 2011 01:36 AM
DrewMD
Suspension & Brakes
Nov 1, 2007 10:33 AM
vaajboy
Sep 8, 2004 06:58 AM
BlackThorN
Aug 5, 2003 06:13 PM
Platoon918
Jun 29, 2002 08:56 PM
