Editing w/crome after tuned w/crome pro?
will the chip settings be ruined as far as extra featchers if one were to edit things like 2step, rev limiter, FTS, etc. on crome after being tuned with crome pro? by any chance will crome erase any settings placed by crome pro?
you will be fine as long as you are using the same version of crome.
Crome 1.4 or older all work together
Crome 1.5 does not work with the older versions.
CromeGold does not work with anything but CromeGold
CromeFree and CromePro doesn't matter. All that matters is what version of crome you are using.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomdata »</TD></TR><TR><TD CLASS="quote">you will be fine as long as you are using the same version of crome.
CromeFree and CromePro doesn't matter. All that matters is what version of crome you are using.</TD></TR></TABLE> so, its safe to say, as long as i have the latest version of crome, i should not have to worry about erasing anything added with a previous version but if i have an older version of crome and i try to make changes on a chip with newer version burned, i may risk erasing a feature?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I »</TD></TR><TR><TD CLASS="quote"> so, its safe to say, as long as i have the latest version of crome, i should not have to worry about erasing anything added with a previous version but if i have an older version of crome and i try to make changes on a chip with newer version burned, i may risk erasing a feature?
No, however the plug-ins originally used to tune the rom need to be installed to properly adjust settings those plug-ins managed.
</TD></TR></TABLE>No, however the plug-ins originally used to tune the rom need to be installed to properly adjust settings those plug-ins managed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
No, however the plug-ins originally used to tune the rom need to be installed to properly adjust settings those plug-ins managed.</TD></TR></TABLE> im sorry, no about which part? and does pro cme with more plugins then free?
06 Habanero-NaVi
Honda Civic (2006 - 2015)
36
Jan 10, 2007 05:01 AM
