h22a not firing PLEASE HELP!!
Old Oct 11, 2008 | 04:42 PM
ride111's Avatar
Default h22a not firing PLEASE HELP!!
HI I have been tring 2 get my prelude going 4 da last 3 days naw i just put a new motor in it had 2 put plenum dizzy etc on new motor az it was a bear motor went 2 start it and it justkeeps turning over some time it will try 2 fire but dosent i have check if it has fuil it dose checked 4 spark and if it was 1#tdc and da dizzy was on 1 it was dont no wat else 2 try any help would be very helpful thanks
Old Oct 11, 2008 | 05:12 PM
Giant_Bean's Avatar
Default Re: h22a not firing PLEASE HELP!! (ride111)
next time, try sentences, they help people understand you. Make sure you have the firing order correct, if you are working from the factory manual, the cap is pictured upside down. Next verify that your injectors are firing. If those check out, then you need to make sure that the motor is timed correctly.
Old Oct 14, 2008 | 02:34 PM
Speedra500's Avatar
Default Re: h22a not firing PLEASE HELP!! (Giant_Bean)
triple check the firing order, make sure your distributor is not flipped 180 degrees, make sure your timing is correct
jinxd12
Aug 9, 2010 12:31 PM
vtec_lude
Aug 22, 2006 09:28 PM
StRoKeD-B16bEj2
49
Jul 28, 2006 11:02 AM
hatchyboy89
Apr 4, 2005 11:44 PM
ismkv8s
Jan 20, 2003 03:54 PM
