93 eg stalled n back fired heip
Old Oct 11, 2008 | 03:47 PM
jwizzie2001's Avatar
Default 93 eg stalled n back fired heip
i was driving on the high way to day i got off n came to a light n and it felt like it was going to die so i gave it gas and it was fine i drove another 300 ft n it stalled i stared it back up and itback fierd . please help
Old Oct 11, 2008 | 04:08 PM
Pothole987's Avatar
Default Re: 93 eg stalled n back fired heip (jwizzie2001)
Did you check to see if it has spark and fuel?
Possibilities:
1) Jumped timing belt teeth
2) main relay for the fuel pump gone/ fuel pump or sending unit gone
3) Coil or igniter gone
4) dizzy ground, or fuel pump ground became loose ( unlikely)
Old Oct 11, 2008 | 04:15 PM
Default Re: 93 eg stalled n back fired heip (Pothole987)
i pulled it into a parking lot n the battery was smoking i guess it was overheating so igot a new batery n it started up n i drove it home but it was surgen the hole time do u think it can be the coil pack
Old Oct 11, 2008 | 04:20 PM
Pothole987's Avatar
Are you sure it was the battery smoking?????? I've only heard of that WHILE THE CAR IS ON FIRE... or your alternator is fooked...
Old Oct 11, 2008 | 04:28 PM
ya it might sound funy but it was my battery i thought it was going to explode i was smoking n there was battery acid comeing out the caps n after i put the new battery in the car started but it surged the whole time . when it first did it the motor hesitated n back fired and all the lights came on
Old Oct 11, 2008 | 05:02 PM
Pothole987's Avatar
Please, have it checked out in a garage. i don't really want to hear about your car catching fire...
as for surging, do you have a Check engine light on?
Old Oct 11, 2008 | 05:15 PM
ther ant any check engine light on i am taking to a honda mechanic tomoro but i just someone would help me or if it happend to someone else i mean a battery cant make that **** happen can it
Old Oct 12, 2008 | 04:17 PM
94dels0lsi's Avatar
bump
Old Oct 12, 2008 | 04:21 PM
Hanmin's Avatar
a battery can cause your car to not start. and die out in odd cases. by surging to you mean the idle is just jumping up and down between a and b rpms? or the lights are dimming and becoming bright? try resetting your ecu.
Old Oct 12, 2008 | 04:29 PM
Default Re: (Hanmin)
how do u reset the ecu in a 93
Old Oct 13, 2008 | 11:39 AM
Pothole987's Avatar
Default Re: (jwizzie2001)
7.5 amp fuse in compartment right beside the battery (under the hood)
did the mechanic say anything??????????????????????????????
CKnight90
May 12, 2014 10:40 PM
siVix
Aug 3, 2011 06:28 PM
bjones
Dec 29, 2008 05:38 PM
IntegraTypeR
Feb 6, 2007 09:23 AM
