SOHC vtec head
Old Jul 28, 2002 | 01:27 PM
4potnick's Avatar
Default SOHC vtec head
I am going to look at one tomorrow that i might buy for a mini-me swap. The guy says it is not together but has everthing but vtec solenoid and cam gear. Anything i should look for when i check out the head? How much do the solenoids run. Any input helps. The head is off a 92 ex
Old Jul 28, 2002 | 06:53 PM
splitime's Avatar
Default Re: SOHC vtec head (4potnick)
i'm looking for similar info.....bump
Old Jul 28, 2002 | 07:44 PM
4gvtec's Avatar
if you have a 88-91 civic crx get the y8 head the 88-91 distrib bolts right up.buy a low mile head complete!
Old Jul 28, 2002 | 09:17 PM
builthatch's Avatar
MiG-21 superfan
makesureall the pins in the rocker arms are there...make sure that the cam journals are not killed...look for severe mating surface marrs, or obvious machining marks (ie- un-deburred coolant passage entries, half circle shapes on the mating surface (you dont want a head that was milled so much its junk)
i say get a head that is togetehr if you dont know what to look for....no offense, but its a lot easier to get a complete piece that requires no guessing
Old Jul 28, 2002 | 09:32 PM
4potnick's Avatar
Default Re: SOHC vtec head (builthatch)
good idea
mudpuppy4life
Jun 9, 2011 07:19 PM
g-ride-si
13
Sep 11, 2006 01:27 PM
PyroVTEC
Dec 25, 2002 04:23 PM
