Preventing Clanking noise from progressive springs?
Hey there guys, I've installed a Eibach Pro Kit with stock shock on my 96 Accord EX (Let's stay on topic, the shocks are still good and pro-kit are compatible, no flamming on me about this) and it's been a few months after the install.
Since the rear of the pro-kits are progressive type springs, I've been hearing some clanking noise whenever I go over speed bumps. If I go really slow on speed bumps, there is no noise.
How do I fix this? I remember on the RSX, Acura also use a progressive type springs for their A-Spec suspension. there is a rubber coating on the exterior on the springs. Is there a way I can solve this?
Do you think a rubber tube cut down the middle and wrapping it will work or should I try another method?
Checked it today, all is good. Isn't progressive type springs suppose to clank sometimes when going over bumps because of the closer windings?
rm07
Nov 1, 2007 03:50 PM
