Suspension & Brakes Theory, alignment, spring rates....
gsr rear sway installed on 95 ex
Old Oct 10, 2008 | 11:40 PM
coupej1's Avatar
Default gsr rear sway installed on 95 ex
i just got a gsr rear sway bar for my daily driver (95 ex) it already has aftermarket rear lower control arms on it. I have just the say bar so what else would i need to install it? brackets, etc... thanks in advance
Old Oct 11, 2008 | 10:44 AM
coupej1's Avatar
anyone?
Old Oct 11, 2008 | 10:56 AM
StylishDOHC's Avatar
Default Re: (coupej1)
you need the d shaped brackets that bolt it to the car, the bushings that go inside those, 4 12mm bolts and nuts, and integra endlinks with bushings
Old Oct 11, 2008 | 04:41 PM
coupej1's Avatar
cool thanks alot stylishdohc!!
Old Oct 11, 2008 | 10:00 PM
egsleepercivic's Avatar
you need the brackets in the first picture in this thread https://honda-tech.com/zerothread/2404910 don't worry his only ripped because he was using to big of a bar with those brackets, stock gsr rear on civic nop problems
Old Oct 13, 2008 | 06:10 AM
alphalanos's Avatar
Default Re: (egsleepercivic)
No it tore because he wasnt using any reinforcment.
Old Oct 13, 2008 | 06:26 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (alphalanos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos &raquo;</TD></TR><TR><TD CLASS="quote">No it tore because he wasnt using any reinforcment.</TD></TR></TABLE>
It tore because he was using a big bar without reinforcement.
As sleepercivic stated, a stock GS-R bar will be fine on an EG Civic, no extra reinforcement needed.
VSM EXtasy
Apr 27, 2005 09:57 AM
MASTRCHANN
May 7, 2004 11:56 AM
95integragsr1984
May 25, 2003 09:26 PM
JCracer723
Mar 31, 2003 09:04 PM
chillly
Dec 21, 2002 06:53 PM
