You all remove oil filter from the engine bay?
Old Jul 28, 2002 | 12:04 PM
Dirt's Avatar
Default You all remove oil filter from the engine bay?
It looks like there is enough room to get at it, unscrew it and bring it up through the top of the engine. With another set of hands or a bunch of rags, it appears like it wouldn't make too much of a mess as long as you drain the oil for a couple hours. My GS-R (because of it's lower intake manifold) makes this impossible and I hated the hot oil running down my arm while under the car!
Do you all do it this way? I'll be changing the oil in the R tomorrow. Thanks.
Old Jul 28, 2002 | 12:08 PM
SurferX's Avatar
Default Re: You all remove oil filter from the engine bay? (BrewCityR)
Yes I change the oil filter from up top. I couldn't do it with my LS but the ITR's shorter intake manifold gives me just enough room to reach down there and twist it on/off as needed.
Old Jul 28, 2002 | 12:23 PM
pyromaster's Avatar
yup, i do it from the top too
Old Jul 28, 2002 | 12:36 PM
TypeR 599's Avatar
Default Re: You all remove oil filter from the engine bay? (pyromaster)
that's a good idea
Old Jul 28, 2002 | 12:38 PM
The Kernel's Avatar
I've got a 1/2 gallon milk jug that I cut in half. I use it to cup the filter, unscrew filter and let it drop in. No mess.
Old Jul 28, 2002 | 12:42 PM
SoCal ITR's Avatar
Default Re: You all remove oil filter from the engine bay? (NBP #0933)
Eh... gotta get under it anyway... I like the milk jug idea though.
01PYITR's Avatar
From the top with no problems or drip/ min amount...
does not pay to do from the bottom.
Old Jul 28, 2002 | 01:18 PM
Dirt's Avatar
Nice. I may try that.
Old Jul 28, 2002 | 01:25 PM
Tweakmeister's Avatar
I'm a bottom guy...gs-r and rs no problems.
Old Jul 28, 2002 | 01:27 PM
skafia's Avatar
25 Year Member
Default Re: You all remove oil filter from the engine bay? (Tweakmeister)
I do mine from the bottom--maybe top would be easier?
Old Jul 28, 2002 | 01:47 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: You all remove oil filter from the engine bay? (skafia)
It is easier. Just reach back under the intake manifold and go nuts. you have enough room to "flip" the filter once you get it unthreaded so you don't dump oil all over the header.
Old Jul 28, 2002 | 03:04 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: You all remove oil filter from the engine bay? (Splat)
get a oil filter relocation kit, makes oil changes very, very easy
later
matt
Old Jul 28, 2002 | 03:15 PM
hungsteR's Avatar
Default Re: You all remove oil filter from the engine bay? (champITR)
Anyone have a link for a fitler relocation kit? I'll have to try the filter from the top next time.
Old Jul 28, 2002 | 03:39 PM
Default Re: You all remove oil filter from the engine bay? (hungsteR)
I should also mention the K&N oil filter has a 1 inch nut welded to the end of it....makes it easier to loosen.
Old Jul 28, 2002 | 10:05 PM
bullz's Avatar
I do that too from the top . Anyone got pics of Oil Relocation Kit. That would be changing the oil fun again.
Old Jul 28, 2002 | 11:04 PM
B18C5's Avatar
Default Re: You all remove oil filter from the engine bay? (illestjr)
Not the greatest pic, but it gives part of an idea. I've always changed my filter from the top, but it hurts my fat (no, I mean muscular) arms and is very hard. I think I'm going to try from under next time. And with one of those milk jugs. Cool.
Old Jul 28, 2002 | 11:13 PM
Tommy_Gunns's Avatar
Do you guys remove the intake tubing and strut bar?
I doubt I could get my fat arms under the intake manifold to unscrew the oil filter.
Old Jul 29, 2002 | 03:35 AM
Turtle's Avatar
Default Re: You all remove oil filter from the engine bay? (Tommy_Gunns)
Mess is good. Its oil...lubricates as well as protects. Plus it gives me a chance to clean things up a bit while I'm under there.
Brandon - Who perfers to get a little messy.
Old Jul 29, 2002 | 04:52 AM
Turtle's Avatar
Default Re: You all remove oil filter from the engine bay? (George Knighton)
Yeah, I agree. I like the relocation kit. Anyone know how much, and if there would be a loss of pressure, how much more oil, and other useful information?
Old Jul 29, 2002 | 05:47 AM
B18CXr's Avatar
Default Re: You all remove oil filter from the engine bay? (401-2001)
If you can't remove your filter by HAND, it's too phucking tight in the first place.
Yack - who thinks oil filter wrenches are a waste of $$$, unless some phucktard previous owner used one.
Old Jul 29, 2002 | 05:49 AM
Willard's Avatar
Default Re: You all remove oil filter from the engine bay? (B18CXr)
I guess nobody has seen the numbers printed around the side of the oil filter... much less uses them correctly.
Will
Old Jul 29, 2002 | 06:00 AM
TsunamiZC's Avatar
Old Jul 29, 2002 | 08:05 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: You all remove oil filter from the engine bay? (tsunami_zc)
On my GS-R, I loosen the oil filter from underneath, then go up top and unscrew it and let it fall into my drain pan. It's still a bit messy, but at least it's not getting on me. Oh, and I still have the stock dual runner intake manifold. It's a tight squeeze, but I can reach it.
Old Jul 29, 2002 | 08:16 AM
martilafox's Avatar
New User
Default Re: You all remove oil filter from the engine bay? (PatrickGSR94)
i change my oil in the morning after it's been sitting overnight.
.....when the filter comes off. . . . no mess!
Old Jul 29, 2002 | 08:33 AM
Turtle's Avatar
Default Re: You all remove oil filter from the engine bay? (martilafox)
You should change your oil after the car is warm. Your oil is a little more thin because of the heat, and you will get more deposits out...just advice.
And for all the people who are concerned about the mess - change your oil from behind the drivers side wheel (grab the filter from behind, not underneith) and you wont have any issues.
Brandon - who has too many stained t-shirts to count. AND wears them out; with pride.
[Modified by 401-2001, 12:35 PM 7/29/2002]
