sunroof maintenance
Old Oct 10, 2008 | 03:22 PM
y2kferari's Avatar
Default sunroof maintenance
I was wanting to get access to the sunroof rails so I could get some grease on them. and get all the leaves and crap that has built up over the years.
and if some one could also give me info on how to replace the sunroof motor, that would be awesome
Old Oct 10, 2008 | 03:30 PM
studioface's Avatar
first of all we need to know what model car it is but to get to that motor you need to pull down the ceiling
Old Oct 11, 2008 | 06:03 PM
y2kferari's Avatar
Default Re: (studioface)
94 ex coupe
Old Oct 11, 2008 | 07:57 PM
DCSportEJ1Civic's Avatar
Default Re: (y2kferari)
you have to pull the headliner.
Old Oct 11, 2008 | 08:05 PM
y2kferari's Avatar
Default Re: (DCSportEJ1Civic)
ok. so if I just want to take the sunroof glass out. how do I do that?
Old Oct 11, 2008 | 08:35 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
If it's like the 6th gen, to remove the glass:
- Get in the car
- Open the sunshade
- Remove the screw on the bottom of the plastic covering the bottom of the rail
- Remove the nuts on the bottom of the glass
- Push up on the glass
- Get out of the car
- Remove the glass through the top of the vehicle
Old Oct 12, 2008 | 12:21 PM
Default Re: FV-QR (NOFX)
idk if you have to pull the whole thing or not. im going to my parents later tonight ill look at my old civic.
Old Oct 12, 2008 | 02:22 PM
y2kferari's Avatar
Default Re: FV-QR (DCSportEJ1Civic)
its not like the 6th gen. no screws or anything to take apart. I'm really just doing cuz I'm bored. But dont find any starting point
Old Oct 12, 2008 | 02:45 PM
NOFX's Avatar
H-T White Ops
Default Re: sunroof maintenance (y2kferari)
Okay, so which is it you really want to do? I see three things here.
- Access rails to clean.
- Replace motor.
- Remove glass.
Old Oct 12, 2008 | 03:03 PM
y2kferari's Avatar
Default Re: sunroof maintenance (NOFX)
access rails to clean
Old Oct 13, 2008 | 12:10 AM
y2kferari's Avatar
anyone?
Old Oct 13, 2008 | 01:10 AM
NOFX's Avatar
H-T White Ops
Since the moonroof on a 5th gen doesn't slide back under the roofskin like a 6th gen, you should be able to access most of the rails by just removing the glass.
I'll check when I wake up in a few ours how exactly to do this
Old Oct 13, 2008 | 04:40 PM
y2kferari's Avatar
Default Re: (NOFX)
anyone else?
Old Oct 13, 2008 | 05:17 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
I checked the manual. It was even easier than I wrote earlier.
- Open sunshade.
- Tilt up glass.
- Remove glass mounting screws.
- Remove sliding glass from bracket.
Old Oct 13, 2008 | 05:25 PM
Mrmatt3465's Avatar
Relating to the topic but not entirely: I noticed my anchor spring on the passenger side is broken. My sunroof works perfect. I'm just curious as to the function of the anchor spring. Anyone have an idea?
VBitter
15
Sep 30, 2009 06:49 PM
bruboy720
Aug 12, 2003 08:33 AM
h22congee!
Sep 19, 2002 07:45 PM
bb2prelude
Sep 16, 2002 02:42 PM
travis
Apr 11, 2002 09:22 PM
