exhaust gasket material
Old Oct 10, 2008 | 02:44 PM
spooty's Avatar
Default exhaust gasket material
so i'm in need of new exhaust gaskets as i have major leaks on both ends of the exhaust pipe after my manifold and before my cat.
i have some material that i think might work, but i would like opinions before i start the process and possibly failing.
the material i have has some kind of carboardish stuff on both sides with corrugated metal sandwiched between. would this work or is it doomed to fail?
please help me! my exhaust sounds horrible : /
i can post pics of the material if needed!
Old Oct 10, 2008 | 02:53 PM
TheMuffinMan's Avatar
He knows where you live!
Any exhaust shop should be able to make you some fairly cheap.
Old Oct 10, 2008 | 03:31 PM
spooty's Avatar
Default Re: (TheMuffinMan)
that's my issue though, dropped all my cash into replacing a bunch of other stuff that needed to be done :/
here's the stuff i have. i would really like to be able to do this tonight so i can drive without hearing exhaust from 3 different places. haha
i think it's some felpro stuff. had a sticker on the other piece that said something about gasket material.
sorry for the crappy pics. my phone sucks in bad lighting
Modified by spooty at 4:39 PM 10/10/2008
Old Oct 10, 2008 | 03:49 PM
FunnyVictor86's Avatar
ive used it ... it sucks it worked for about a month and then i blew them out ... i think im just going to have to get some made ... the leak is killing me at low rpm
Old Oct 10, 2008 | 03:54 PM
spooty's Avatar
Default Re: (FunnyVictor86)
w3rd. just the info i was needing to know. quick fix until payday! thanks!
Old Oct 10, 2008 | 04:00 PM
no problem lol
Old Oct 10, 2008 | 07:48 PM
Gurvinder Minhas's Avatar
There is a gasket made for Subaru Legacy that looks like the aftermarket 421 header shape just the bolt hole are off by a bit. I had the same problem as the rest that material works well only for about am month tops and then good bye! This gasket is metal and has lasted me for a good 3 moths and still going strong.
if you guy want i can dig up the part number
Old Oct 10, 2008 | 11:00 PM
spooty's Avatar
Default Re: (Gurvinder Minhas)
well, now that i have the pipe off, i've decided against using the homemade gasket. i'm just going to buy one in the pm. are there any brands that i should stay away from or look for? oh yeah! upon further inspection, i only have one bad gasket! woohoo! it's the one coming from the manifold! still not great tho :/
Old Oct 10, 2008 | 11:35 PM
the one from the exhaust manifold to the header ... or the one from the header to the downpipe?
Old Oct 11, 2008 | 12:14 AM
spooty's Avatar
it's the one from the manifold to the pipe. autozone has these and that's probably going to be my best bet. too bad i don't need the other gasket. haha
http://www.autozone.com/R,2451...l.htm anybody use this particular set before?
Modified by spooty at 1:38 AM 10/11/2008
Old Oct 12, 2008 | 11:08 AM
oh those you can definately get at autozone no problem ... im stuck with gasket maker gaskets because they dont sell gaskets for my megan header and megan wants like 25 bucks for their junk ones
Old Oct 12, 2008 | 11:12 AM
spooty's Avatar
i went yesterday and ordered the one from the link that i found. no more leaks when it comes in tomorrow!
Old Oct 12, 2008 | 08:02 PM
sweet ... i still have to get mine custom fab. but i dont know where i can get that done ...
PowerLeg
Jan 2, 2009 11:39 PM
hondacrx_3
Jun 22, 2005 09:36 PM
Traction
Jul 7, 2004 10:28 PM
prelude10
Jan 10, 2003 02:55 PM
jdmspoonitr
Aug 27, 2002 10:20 PM
