h22 eg coil install HELP!!!
Old Oct 10, 2008 | 02:43 PM
hatchback13sec's Avatar
Default h22 eg coil install HELP!!!
i have 95 dx and i need to install blaster coil without msd box cuz my h22 is external coil dist..im using eg harness what wires need to be spliced to run the blaster coil?
Old Oct 10, 2008 | 02:45 PM
DTA-Zombie's Avatar
Default Re: h22 eg coil install HELP!!! (hatchback13sec)
the ones for the coil...2 wires I wanna say 1 is red 1 is white might be black but I dunno for sure...
Old Oct 10, 2008 | 03:04 PM
Default Re: h22 eg coil install HELP!!! (DTA-Zombie)
and those go straight to the coil negative and positive what colors go to where lol im never doing a h22 swap again
Old Oct 11, 2008 | 01:56 PM
anyone...............i need help
Old Oct 11, 2008 | 04:01 PM
914b16's Avatar
take the dizzy apart youre gona see the internal coil.there are only 2 wires that conect to the internal coil.one is black thats ground and one is white thats power.its pretty straight foward...and remove the internal coil..
Old Oct 12, 2008 | 12:38 PM
Default Re: h22 eg coil install HELP!!! (914b16)
i have a external coil dist i know how to do the internal coil but i hav ext coil and it would be easier to hook blaster coil instead of wiring the stock coil
Old Oct 12, 2008 | 02:30 PM
DCSportEJ1Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 914b16 &raquo;</TD></TR><TR><TD CLASS="quote">take the dizzy apart youre gona see the internal coil.there are only 2 wires that conect to the internal coil.one is black thats ground and one is white thats power.its pretty straight foward...and remove the internal coil..</TD></TR></TABLE>
USDM h22 have external coils. JDM's have internal coils.
im assuming you have a usdm? if your stock coil is still hooked up figure out which is positive and which is negitive. then putt them to the blaster coil.
Old Oct 12, 2008 | 10:03 PM
Default Re: h22 eg coil install HELP!!! (DCSportEJ1Civic)
the stock coil isnt hooked up cuz the h22 is in the car and im using the eg harness which doesnt hav a plug for a coil and i take it apart an theres every color goin to something inside the dist i need to know what color wires i cut and run to the coil
Old Oct 13, 2008 | 02:52 PM
Rob_O's Avatar
The MSD website probably has instructions on how to wire their external coil kits. Just use the wires they tell you to use
Old Oct 16, 2008 | 11:51 AM
Default Re: (Rob_O)
nobody on here knows how to do this anyone????????????????????????/
niterider96cord
Feb 3, 2010 05:04 PM
HYB90RID
Jan 20, 2010 05:16 AM
TopEndUSA
Sep 15, 2006 06:49 PM
turboH22Aakkord
Jul 22, 2005 08:05 AM
JDMBB2
Nov 15, 2004 04:09 PM
