zc sohc non-vtec swap into a 91 crx si. which engine harness do i need?
i've been browsing forums and all over the web, and i still don't know exactly which engine harness i need. i've been getting mixed answers, so can someone please help me out. help would be muchly appreciated.
setup: zc sohc NON-VTEC swap into a 91 crx si
i found this answer on the web. it is the same question i'm asking, but can someone confirm it.
http://www.superhonda.com/foru...85062/
Modified by socalibur at 2:02 PM 10/10/2008
Modified by socalibur at 2:06 PM 10/10/2008
i understand that theres 3 different ZC's. DOHC, SOHC non-vtec, and SOHC vtec.
so many different answers on the web. please, someone that knows, help me!
so i really don't need to convert anything???
i found this answer on the web. its the same question i'm asking too. can anyone confirm?
the reason why i'm asking is because the swap i'm getting is complete, minus the engine harness. so the last thing i want to do is buy the wrong engine harness that i need for this swap.
Just so you know....the jdm sohc zc and the usdm Si engine are the same engine. The "only" difference is that the zc has a better cam that makes 10 peak hp more...only at higher rpm with a bit of loss on the low.
I had this motor in my car. It's basically identical to a D16A6, except the cam is slightly more agressive and it was listed as having 116hp stock opposed to 108hp in the A6. It's a direct drop in if you have an si. It was a good motor until I blew it up lol.
bellako si 91
Jul 1, 2011 11:10 PM
Redemption
Sep 15, 2009 04:42 AM
