crx hf vss jdm cluster?
what do i need to buy to run my jdm crx cluster in my hf.i have it wired up and the only thing not working is the speedometer.do i need to be a evss or something.im lost any help would be appreciated.if i do a swap can i use the vss on the new motor or will i have to buy another one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno »</TD></TR><TR><TD CLASS="quote">http://www.angelfire.com/ca/DrOhm/SiRcluster.html</TD></TR></TABLE>
Dude, that's a totally different cluster and the wiring on that EDM cluster is completely different.
To the original poster, yes, you will need an electronic VSS to get your JDM cluster to work. You can also ghetto rig it to use the cable VSS, but it's alot more work.
