Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch wont bleed.....
Old Oct 10, 2008 | 07:49 AM
RyanStevenPhillips's Avatar
Default clutch wont bleed.....
alright guys, i just installed a jdm h22 in my prelude. everything is fine, except i cant get pressure in my clutch pedal no matter what i do. ive tried bleeding it multiple times, probably pumping the clutch pedal 1000x. the fluid will get all the way to the slave cylinder, but will never go through it. literally, if you pump the pedal without the slave there it will come out in a full spout, but it just wont enter the slave.(ive tried 2 different slave cylinders. is this just the kind of thing where you just have to keep doing it until it finally gets to the slave, or am i doing something wrong???
process: tighten down slave bolt, pump clutch pedal multiple times while adding brake fluid to master cylinder, hold clutch to floor, loosen slave bolt to let air out, repeat.
thanks
Old Oct 10, 2008 | 01:42 PM
Default Re: clutch wont bleed..... (RyanStevenPhillips)
I tried doing it again... still nothing. Any ideas?!?!
Old Oct 10, 2008 | 03:20 PM
Never mind. It just decided to go on the 8th attempt when I was trying it by myself.
Old Oct 10, 2008 | 08:48 PM
crx-b18c's Avatar
pull out all the way bleeding screw and cleaning very good and then try again good luck
RyanStevenPhillips
Nov 9, 2024 10:03 PM
prodjay10
Honda Civic (2001 - 2005)
Aug 19, 2017 08:08 PM
alx_90ef
Jun 14, 2009 01:30 PM
kcxtremeaccord
Oct 23, 2004 07:27 PM
safe driver
Nov 14, 2001 03:23 PM
