Suspension & Brakes Theory, alignment, spring rates....
heading to CMP today.. need some setup advice!
Old Oct 10, 2008 | 05:10 AM
turbociv910's Avatar
Default heading to CMP today.. need some setup advice!
Hi all, im heading to CMP for a tarheel z roadcourse day. This is my first time in a fwd car and i have been frantically trying to get it set up.
I have a 99 civic si stance(15way) coil overs,ctr swap w/lsd, stock sways, itr upper strut, nitto nto1s.
What should my tire pressure be cold?
How stiff should my shocks be set in the be front and rear?
alignment is
front- 1/8th out, -2 camber
rear- 0 toe, -1.5 camer
Thanks!!
Old Oct 10, 2008 | 12:18 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: heading to CMP today.. need some setup advice! (turbociv910)
If you don't understand adjustments why buy adjustable parts?
Old Oct 10, 2008 | 04:38 PM
alphalanos's Avatar
Default Re: heading to CMP today.. need some setup advice! (***$nyper)
Tire pressure is trial and error. Shocks should probably be front stiffer than the rear. Fairly stiff on a road course, probably near the upper end of the adjustment.
Old Oct 10, 2008 | 07:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">If you don't understand adjustments why buy adjustable parts?</TD></TR></TABLE>
because i can get some suggestions from other people that dont mind helping
Old Oct 11, 2008 | 07:00 AM
mattbatson's Avatar
ignore stupid responses on here...some people have too much time on their hands.
I dont know about running stiffer front than rear. On my FWD I run stiff rear and softer front.
I would recommend 0 toe on the front and slight toe in on the rear.
Camber is fine.
What kind of tires are you running?
Start about 30psi and go from there. Mostly looking for around 37 psi hot.
I've been several times in my ITB car..you'll enjoy it.
Old Oct 11, 2008 | 07:29 AM
PIC Performance's Avatar
Your damping settings will depend on your dampers. What works for one does not necessarily work for another, especially when you're talking about different manufacturers. You'll need to at least know how damping works, how well your particular dampers are valved and how well they suit your particular spring rates (and for that matter, how suitable those spring rates are for your application).
Old Oct 11, 2008 | 08:37 AM
mattbatson's Avatar
Default Re: heading to CMP today.. need some setup advice! (PIC Performance)
for fine tuning, it can get really complicated and involve lots of testing time out on track.
for ballpark so your car isnt handing horribly out on your first day...I would recommend setting compression/rebound softer in the front and stiffer in the rear.
I have no idea what spring rates your running front and rear, but assume you will not be changing these before the track day.
I run just off full stiff on the rear yellow konis and halfway between soft/stiff on the front yellows.
I run 350lb springs up front and 650 rear (suzuki swift GTI)
It handles great, with the alignment figures I gave you...I've run 1.58's at CMP making 92hp ATW.
Old Oct 11, 2008 | 05:12 PM
Default Re: heading to CMP today.. need some setup advice! (mattbatson)
i acctaully thought i did very well today, out of the 15 points of adjustments, i had 13 in the rear, 10 in the front, 35 psi hot rear, 33 psi hot fronts. the only other car that was a good cat and mouse was a type r with similar mods.
Old Oct 11, 2008 | 07:29 PM
mattbatson's Avatar
great, it is a fun track and pretty safe...
what kinda lap times were you pulling?
any in-car?
Old Oct 12, 2008 | 11:22 AM
no, no track times..some pics of me chasing a gtr thought.. lol
two of the new gtrs were out there haulin ***
Old Oct 13, 2008 | 11:38 AM
some pics-
cheesebox
21
Apr 13, 2006 05:28 PM
ghettoracer
34
Aug 5, 2003 09:22 AM
alu95
10
Mar 21, 2003 12:50 PM
tjtruong
Jun 26, 2002 05:40 PM
Flux
Mar 28, 2002 09:13 PM
