Brake light Question
Have a 97 Hatch Dx. For some reason the right brake light is out and I cant find out what is wrong with it. Put new bulb and fuse but still nothing. Any ideas.
put a voltmeter accross the socket and press the brake, see if you get voltage. or it can even be a bad bulb you got. switch the bulb with the other side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">put a voltmeter accross the socket and press the brake, see if you get voltage.</TD></TR></TABLE>
I agree. And if voltage is not detected, then check whether voltage (with brake pressed) is detected from the power wire (GRN/WHT) when grounded to the body frame and whether the ground wire (BLK) has continuity with the body frame.
rambler
36
Nov 29, 2005 09:10 AM
