rear camber washer trick
haha i think ima do the washer trick after i slam, cause fucn i dont have the money for a good camber kit, and i dont wana go with some ebay ones. so ima washer my shittttttttt dawk
From: Somewhere in the United States, united states
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej6hatchie »</TD></TR><TR><TD CLASS="quote">i dont wana go with some ebay ones. so ima washer my shittttttttt dawk
so your saying putting washers on is better than buying ebay camber
</TD></TR></TABLE> so your saying putting washers on is better than buying ebay camber
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej6hatchie »</TD></TR><TR><TD CLASS="quote">haha i think ima do the washer trick after i slam, cause fucn i dont have the money for a good camber kit, and i dont wana go with some ebay ones. so ima washer my shittttttttt dawk
Lol!!! I've had a good camber kit in the back before, and I'm going to use washers this time. I'm going Skunk up front though.
</TD></TR></TABLE>Lol!!! I've had a good camber kit in the back before, and I'm going to use washers this time. I'm going Skunk up front though.
deeemn 6 washers ?Lol what bolts you running?
according to this thread stock bolts safest limit is 2 washers
https://honda-tech.com/zerothread?id=2300203
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">Works but isn't 100% accurate. Just do it right and get a camber kit/alignment. Saves your tires in the long run.</TD></TR></TABLE>
What do you mean not 100% accurate? Having a little negative camber is good for handling and won't wear your tires, thats an alignment issue. Have you ever looked at the rear wheels on a CRV? They have a ton of negative camber from the factory. The washer fix works great.
yup, definately works.
if you need more than 3-5 washers, i'd recommend changing the studs out for longer ones just so you have enough thread left to tighten on.
i did it, and i [freak]ed up my thread so i had to get it rethreaded by honda... PITA...
but my rear wheels are straight, and the basic rule i heard was a washer per inch dropped.. it worked for me..
but listen to mashimaro and get longer bolts if using more than 3
i regret buying my blox rear camber kit big time! for one its only been 1 year and its rusted out and its never been easy to adjust and get both sides equal.
with the washers as long as they're the same thickness on each side it'll be perfect. its almost impossible to get these camber kits adjusted right and since i threw my stock ones away now i cant do the washer trick!
ahh thank you thank you. what about the bolts what size bolts do you use if you wanna extend em? Do you jus get some regular bolts at home depot or somethin or do you get em from honda?
Washer trick works fine, collectively I've put close to 60k miles on the ol washer trick, between 3 cars. I have 5 washers thick on my EM1 (typically I only run 3 on eg's) and its great. In the front i have Skunk2 upper control arms adjusted all the way out and I have -.9 degrees of camber in the front and -.6 in the back.
Its a daily so I'm not too concerned with Madd Trackkk action, I'm into saving my tires.
well eventually when i run some upper cash moneys... washers sound rape right now
