Location of the Radiator fan switch
i wanna say its on the back of the block. may be on the thermostat housing though although i thought that was only the newer engines...
Modified by D16SiHatch at 12:36 AM 10/10/2008
The system uses a relay which is on the fender near the battery and a switch which is on the back of the block.
When the coolant reaches a certain temp, the swicth on the back of the block turns on and sends a signal to the relay which then flips to send 12v to the fan motor.
